Wireless
6717 Discussions
AX200 only connects with 80Mhz to my Wifi Access Point which is capable of 160 Mhz
usefulvid
I am using AX200 via the M.2 Slot.
Driver Version is 21.70.0.6
Access Point is FritzBox 6660
https://en.avm.de/products/fritzbox/fritzbox-6660-cable/technical-specifications/
It always connects with 80Mhz I also manually allowed 160 Mhz in my access point. Is there a specific channel which must be used?
AlHill
usefulvid
Thanks for the Link but this is already activated on my site:
I think this is what is the solution from the other thread but this does not solve my problem
AlHill
Did you add the AX200 to your laptop or did the laptop come with the AX200?
Doc
usefulvid
AlHill
Well, that is part of the problem. You cannot add the adapter of your choice without consulting with the laptop manufacturer for compatibility.
Doc
usefulvid
The laptop has an m.2 slot for wifi cards, driver installation worked flawlessly
AlHill
Then, why do you have problems?
Doc
usefulvid
AVM could solve it. Radar transmission from a nearby weather station.
The AX200 is working fine and not "part of the problem".
