- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
We have brought up a dell laptop which has Intel AX210 card with Ubuntu OS running 21.04 release and has 5.11.0-31-generic. The first problem was that the wireless card was not coming up because of iwlwifi-ty-a0-gf-a0.pnvm . We removed the file after which able to bringup the interface. Now we are unable to set the country code to US either via "iw reg set" command or via crda file. By default it picks up country based on scanning information .
Posting this question to find out if there is any other way to set the country code to US? If I place the laptop in Isolated place by having only 1 AP seen with US country code then the interface is able to pick the country code and scan through 6Ghz Channels.
Note : For now only FCC supports 6E channels so to test that we need to set the Country code to US in client.
OS information:
uname -a
Linux sitindia-Latitude-3320 5.11.0-31-generic #33-Ubuntu SMP Wed Aug 11 13:19:04 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
cat /proc/version
Linux version 5.11.0-31-generic (buildd@lcy01-amd64-009) (gcc (Ubuntu 10.3.0-1ubuntu1) 10.3.0, GNU ld (GNU Binutils for Ubuntu) 2.36.1) #33-Ubuntu SMP Wed Aug 11 13:19:04 UTC 2021
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 21.04
Release: 21.04
Codename: hirsute
dmesg:
[364223.003741] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[364223.003918] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[364223.009450] Intel(R) Wireless WiFi driver for Linux
[364223.013757] iwlwifi 0000:2b:00.0: api flags index 2 larger than supported by driver
[364223.013771] iwlwifi 0000:2b:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 93.8.63.28
[364223.014133] iwlwifi 0000:2b:00.0: loaded firmware version 59.601f3a66.0 ty-a0-gf-a0-59.ucode op_mode iwlmvm
[364223.031412] iwlwifi 0000:2b:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[364223.251124] iwlwifi 0000:2b:00.0: base HW address: 14:18:c3:88:c2:32
[364223.269109] thermal thermal_zone6: failed to read out thermal zone (-61)
[364223.270816] iwlwifi 0000:2b:00.0 wlp43s0: renamed from wlan0
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Vivektrivedi, Thank you for posting in the Intel® Communities Support.
In reference to your question, we will do further research on this matter to provide the most accurate assistance on this topic, for us to be able to do that, please provide the SSU report:
Albert R.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Vivektrivedi, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Alberto,
Thanks for extending support. Please find attached output file created by running ssu.sh .
Actually it threw error that operating system is not supported. I continued with "y" to scan the system and collect information.
Please let me know for anyother info required.
root@sitindia:/home/sitindia# ./ssu.sh
This product is not supported on this operating system.
Would you like to try to scan? (y/n)
y
/bin/ping: wlp43s0: Temporary failure in name resolution
root@sitindia:/home/sitindia# iwconfig
lo no wireless extensions.
enxe89f8001e14e no wireless extensions.
wlp43s0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=-2147483648 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
root@sitindia:/home/sitindia# lspci
0000:00:00.0 Host bridge: Intel Corporation Device 9a14 (rev 01)
0000:00:02.0 VGA compatible controller: Intel Corporation Device 9a49 (rev 01)
0000:00:04.0 Signal processing controller: Intel Corporation Device 9a03 (rev 01)
0000:00:07.0 PCI bridge: Intel Corporation Device 9a23 (rev 01)
0000:00:0d.0 USB controller: Intel Corporation Device 9a13 (rev 01)
0000:00:0d.2 USB controller: Intel Corporation Device 9a1b (rev 01)
0000:00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller
0000:00:12.0 Serial controller: Intel Corporation Device a0fc (rev 20)
0000:00:14.0 USB controller: Intel Corporation Device a0ed (rev 20)
0000:00:14.2 RAM memory: Intel Corporation Device a0ef (rev 20)
0000:00:15.0 Serial bus controller [0c80]: Intel Corporation Device a0e8 (rev 20)
0000:00:15.1 Serial bus controller [0c80]: Intel Corporation Device a0e9 (rev 20)
0000:00:16.0 Communication controller: Intel Corporation Device a0e0 (rev 20)
0000:00:17.0 System peripheral: Intel Corporation Device 09ab
0000:00:1d.0 PCI bridge: Intel Corporation Device a0b1 (rev 20)
0000:00:1f.0 ISA bridge: Intel Corporation Device a082 (rev 20)
0000:00:1f.3 Multimedia audio controller: Intel Corporation Device a0c8 (rev 20)
0000:00:1f.4 SMBus: Intel Corporation Device a0a3 (rev 20)
0000:00:1f.5 Serial bus controller [0c80]: Intel Corporation Device a0a4 (rev 20)
0000:2b:00.0 Network controller: Intel Corporation Device 2725 (rev 1a)
10000:e0:17.0 SATA controller: Intel Corporation Device a0d3 (rev 20)
10000:e0:1c.0 System peripheral: Intel Corporation Device 09ab
10000:e0:1c.4 PCI bridge: Intel Corporation Device a0bc (rev 20)
10000:e1:00.0 Non-Volatile memory controller: SK hynix Device 174a
root@sitindia:/home/sitindia# dmesg
[1201262.123010] Intel(R) Wireless WiFi driver for Linux
[1201262.134930] iwlwifi 0000:2b:00.0: api flags index 2 larger than supported by driver
[1201262.134943] iwlwifi 0000:2b:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 93.8.63.28
[1201262.135326] iwlwifi 0000:2b:00.0: loaded firmware version 59.601f3a66.0 ty-a0-gf-a0-59.ucode op_mode iwlmvm
[1201262.139776] iwlwifi 0000:2b:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[1201262.362187] iwlwifi 0000:2b:00.0: base HW address: 14:18:c3:88:a1:d5
[1201262.379232] thermal thermal_zone6: failed to read out thermal zone (-61)
[1201262.384249] iwlwifi 0000:2b:00.0 wlp43s0: renamed from wlan0
Vivek
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Vivektrivedi, You are very welcome, thank you very much for providing that information and the SSU report.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
Is this a new computer?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes?
The wireless card, did you purchased it separately or did it came installed on the computer?
By any chance, do you know the wireless driver currently installed in your laptop? For some reason that information is not showing in the SSU report.
Albert R.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Albert, please find comments inline below.
<Vivek> Yes, it is a new Dell laptop with AX210 Card available by default. I have attached lspci, lshw and modinfo iwlwifi for refrence.
<Vivek> In previous generations of intel products, we could set the country code using iw reg set command. But currently we are unable to set the country code. FYI, I want to use 6Ghz channels but it is currently supported only in US country code and not in IN. So i need a provision to change the country code .
<Vivek> I upgraded ubuntu version and also kernel to 5.11.0.34 which supports AX210 firmware.
<Vivek> It came with the laptop.
<Vivek> I'm not sure on how to check the driver version. Attached modinfo of iwlwifi for your reference.
<Vivek> Any place . This issue is specific to country code setting in laptop for 6Ghz support.
Vivek
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Vivektrivedi, Thank you very much for sharing those details.
We will now do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hello Vivektrivedi, I just received an update on this matter.
I just sent you an email, please verify your inbox.
Albert R.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi
I've got same problem on setting 6GHz Wi-Fi.
Could you let me know how to set the country code to US on AX210 operating in Ubuntu 21.04 (Kernel 5.11.0-16-generic) ?
FYI,
I've also tried "iw reg set US", but phy#0 still shows country code KR. (with all 6GHz frequencies disabled)
Thank you in advance
Sol
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
It´s not possible to set the country as a user by design. Country selection is purely done by firmware. The regulatory db (which bands are allowed / which TX power and so on) is also embeeded in the firmware itself. It can only be updated by Intel.
The firmware image is obviously signed, so no way to change it easily..
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
