I'm having an issue with my wireless adapter, Intel(R) Wi-Fi 6E AX210 160MHz, where connectivity cuts out randomly. Each time I receive the following errors in order:
5007 - TX/CMD timeout (TfdQueue hanged)
5005 - Intel(R) Wi-Fi 6E AX210 160MHz : Has encountered an internal error and has failed.
5002 - Intel(R) Wi-Fi 6E AX210 160MHz : Has determined that the network adapter is not functioning properly.
I have updated drivers, I have turned off the power saving option in the network adapter settings in device manager, try reinstall the driver. but the issue still persists.
Hello Philbert,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues with your wireless adapter.
- Do you remember if this issue happened after a new Operating System update or Wireless driver update?
- Is this a laptop or desktop system? Could you provide your system's model?
- Have you checked if this issue happens on different networks?
- Were you able to have your wireless connection in a normal/expected performance before?
- Have you rebooted your access point, router, or modem?
- Are you able to reproduce the same issue while on a hardwired connection?
- Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
Jean O.
Hello Philbert,
I hope you are doing fine.
Jean O.
Hello, @Philbert.
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
