Wireless
8851 Discussions
Intel(R) Wi-Fi 6E AX211 160MHz (Netwtw12) error internet connection drop on 5ghz
SpaceChrome22
I have issues with this wireless adapter (Intel(R) Wi-Fi 6E AX211 160MHz) I have a custom built Desktop with a PRO-Z690-A-WIFI-DDR4 Motherboard, I7 12700k CPU, DDR4 32gb and a RTX 4070ti on a install of windows 11
THE ERROR
(The description for Event ID 5007 from source netwtw12 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer
if the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\NDMP14
The message resource is present but the message was not found in the message table)
The problem with the AX211 is it drops out on the 5ghz mode when under load such as downloading ,speed test or gaming with a netwtw12 cannot be found in the event viewer. I have tried all the drivers from motherboard manufacture and even drivers from intel none of them resolve the issue. With the latest driver the netwtw10 error does not occur only the netwtw12 does. If I use a older driver it gives the netwtw10 but not the netwtw12 either way I get constant 5ghz drops and loose connection completely even on a clean install of windows 11 this doesn't fix the issue please fix had this issue since late 2022.
SpaceChrome22
This is the same issue as I have describe on this forum.        https://community.intel.com/t5/Wireless/Intel-R-Wi-Fi-6E-AX211-160MHz-Netwtw12-and-Netwtw10-errors/m-p/1453378#M45289
However on the forum in the link I also had the netwtw10 error as well because the older driver I had installed would throw that up instead of the netwtw12 in the event viewer. If I use the latest driver on either the motherboard manufacturer or on the intel website it will not fix the issue even on a clean install of windows 11 it still seems to have the same problem.
Similar issues are listed below
netwtw12 error newest driver
https://community.intel.com/t5/Wireless/description-for-Event-ID-6062-from-source-Netwtw12-cannot-be/m-p/1453341/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExEUEJRS1RPQkNTQUdPfDE0NTMzNDF8U1VCU0NSSVBUSU9OU3xoSw#M45286
netwtw10 error older driver
https://community.intel.com/t5/Wireless/Windows-11-Event-Viewer-The-description-for-Event-ID-6062-from/m-p/1414014
Possible connection to this forum as well
https://community.intel.com/t5/Wireless/AX211-and-AX201-Problem/m-p/1488201#M47747
@Alberto_R_Intel
DeividA_Intel
Hello SpaceChrome22,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6E AX211.
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Bluetooth working?
3. Are you using the antennas that came with the adapter?
4. What is the brand and model name of your router/AP?
5. What is the BIOS version installed?
Deivid A.
SpaceChrome22
1. Original Adapter ax211
2. Yes Bluetooth is working
3. Yes Original
4. Windstream T3260 made by Actiontec  https://www.actiontec.com/t3260/
5. Latest version AMI BIOS (7D25vAC) 2023-05-22 9.43 MB https://www.msi.com/Motherboard/PRO-Z690-A-WIFI/support#bios
DeividA_Intel
Thanks for your response. Based on your issue, please try the following:
1. Try the "Recommended Settings for 802.11ax Connectivity":
2. Perform a clean install of the Intel driver:
3. Perform all the Windows updates, including the optional.
4. Check for any firmware update for your AP.
5. Check with MSI to confirm if there is any malfunction with the motherboard.
Deivid A.
SpaceChrome22
1. Try the "Recommended Settings for 802.11ax Connectivity.
       // Has default settings already.
2. Perform a clean install of the Intel driver.
      // I have already clean installed the latest driver for ax211 from both motherboard manufacturer and also from intel neither works.
     //  I have already tried updating to latest drivers on windows 11 and also latest updates. I have also clean installed windows 11 and it has the same issue.
     //  I am currently on the latest firmware for my AP.
    // That they are aware of there is not any malfunction everything else works correctly.
Is the router the problem or the Wi-Fi adapter. All of my other devices connect to 5ghz and have no issue. The ax211 however looses connection constantly at random times but mostly under load. The 2.4ghz connection works on the ax211 however that cuts my internet speed drastically down compared to the 5ghz.
DeividA_Intel
Thanks for the confirmation. In order to investigate this issue can you please run a new Intel® System Support Utility (Intel® SSU) report?
Deivid A.
SpaceChrome22
Here is the new ssu file.
Ave007
Hello, I also have such errors.
https://community.intel.com/t5/Wireless/AX210-and-netwtw12-errors/m-p/1496478#M48232
But my Wi-Fi and Bluetooth work stably.
Intel support did not help me, but only sent me to Microsoft and the laptop manufacturer.
DeividA_Intel
Thank you for the information provided
Deivid A.
SpaceChrome22
3Fees
AC Wifi 5 Router does not have any settings to run on AX, only Wifi 6 and 6E wifi routers have that setting, further AC routers can connect 80 MHZ max. Wifi 6 160 MHz is native,, 211AX wifi 6E has 3 bands and runs best on 6Ghz band and for that need a 6E wifi router and may be able to squeeze by with Wifi 6 router.
Good Luck
Cheers
3Fees
SpaceChrome22
My router supports 160Mhz channel width. Also the Wi-Fi adapter is backwards compatible with older connection types such as ac,n so there should be no issue with connections. Also when I google max channel width for ac it has 160Mhz as the max.
Magic-Light-Boxes
Hi SpaceChrome, I've been having the same problems and may have found a partial fix. My motherboard is a Z790-P Wifi 6E, also has the AX211, and comes with two attachable wifi antennas. Out of curiosity and stupidity, I decided to remove one of the antennas (although I could never recommend doing this), and that somehow has fixed the stability issues.
Of course, it about halved my wifi speed, but it's been preferable to disabling 802.11n/ac/ax entirely. Hopefully this proves to aid in figuring out a real solution.
SpaceChrome22
Intel is supposed to be looking into the issue. Hopefully they figure out what might be the cause of it.
DeividA_Intel
Thanks for your patience. Based on the investigation, I recommend you try the latest driver version 22.230.0 and if the issue persists with this driver, you must check with MSI since the wireless card may need to be replaced.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
asteele1
Hey Deivid,
We are having this issue company wide, has there been any solution to this? ALL the above steps have been tried with no success.
Adam
JustinZ
Hi Deivid,
Do we have any further updates regarding this issue?
I've encountered with this since I got my new PC:
MSI B760M Mortar wifi DDR5 with the same AX211 / 4070Ti /13700F
Every time I open game like dying light 2 the 5G wireless connection gets killed. 2.4G works fine tho.
Logs:
Error 9/1/2023 12:41:15 AM Netwtw12 5005 None
Intel(R) Wi-Fi 6E AX211 160MHz : Has encountered an internal error and has failed.
Error 9/1/2023 12:41:15 AM Netwtw12 5002 None
Intel(R) Wi-Fi 6E AX211 160MHz : Has determined that the network adapter is not functioning properly.
Error 9/1/2023 12:41:15 AM Netwtw12 5007 None
Also every time I tried to install different drivers (all the drivers from OEM and intel website), I always saw the below errors:
Information 9/1/2023 12:25:33 AM Kernel-PnP 420 None
Device PCI\VEN_8086&DEV_7A70&SUBSYS_00948086&REV_11\3&11583659&0&A3 was deleted.
Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
Information 9/1/2023 12:27:42 AM Kernel-PnP 430 None
Device PCI\VEN_8086&DEV_7A70&SUBSYS_00948086&REV_11\3&11583659&0&A3 requires further installation.
Information 9/1/2023 12:27:43 AM Kernel-PnP 400 None
Device PCI\VEN_8086&DEV_7A70&SUBSYS_00948086&REV_11\3&11583659&0&A3 was configured.
Error 9/1/2023 12:27:43 AM Kernel-PnP 411 None
Device PCI\VEN_8086&DEV_7A70&SUBSYS_00948086&REV_11\3&11583659&0&A3 had a problem starting.
Driver Name: oem37.inf
Service: Netwtw12
Lower Filters:
Upper Filters: vwifibus
Problem: 0x0
Problem Status: 0xC00000E5
I've tried the latest version of driver 22.240.0 but got no luck.
3Fees
Greetings:
Intel AX211 is a tri-band wifi card with preference to 6 Ghz band @160Mhz . Its trying to handshake at 6 Ghz connection speed. Buy a wifi 6E router and problem solved, a very very few AX211 cards run well on Wifi 5 not only is Wifi 5 limited to 80 Mhz, there many many more features that Wifi 5 is missing and that a Wifi 6E card is expecting and trying to load the drivers for. You have a high end wifi card why not a matching wifi router ?
                               Cheers
                               3 Fees
Zonearc
Not sure that's the issue. I have Eero 6E routers and a Lenovo Legion with the AX211 wifi chipset. I'm being disconnected at random as well. BIOS, Drivers, etc up to date.
3Fees
Since the AX211 came installed Lenovo would use a mobo with 600 series chipset, the issue most likely is a problem with connections from your cable modem to eero 6e router or settings.
from eero: Can I use eero with my current ISP ?
"Comcast: There are a few ways to set up eero’s while using Comcast/ Xfinity. You can set up your eeros behind your existing router, in either double NAT or bridged mode (if using either of these methods, it’s recommended to disable the wifi broadcast on the Xfinity gateway, unless you are also subscribed to Xfinity’s TV service). Alternatively, you can bridge your Xfinity gateway, and only use eero for all of your devices (if you choose to do this, only the Gateway eero can be connected to the Xfinity gateway with an ethernet cable)."
There are  others, ATT U-Verse, ect.
Cheers
3Fees
