Wireless
8982 Discussions
Intel (R) Wireless-AC 9560 160 MHz Problem
StephanyR
Dear Intel,
The wireless network driver/adapter suddenly stopped working yesterday. My computer is MSI GS65 Stealth Thin 8RF with windows 10 as an operating system.  Even after installing the latest driver from Intel's website (version: 22.30.0.11, driver date: 20-Jan-21), it is still not working with an error code:
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
Please tell us what to do because a laptop with no wireless connection is not useful if there's no ethernet..
Thank you in advance.
sdWer
Same problem
Huynhthinh
Go to device Manager and see if Intel (R) Wireless-AC 9560 is disabled or enabled. Please let us know how you are doing! Thank you
sdWer
Intel (R) Wireless-AC 9560 is disabledQQ截图20210314104321.pngQQ截图20210314104321.png
Huynhthinh
You install it to enable ! thank you
StephanyR
It is enabled, and even though it is enabled error code 10 is present and the wifi is not working on the laptop
Huynhthinh
Error code 10 is the driver error code that is not working, it includes many reasons, how much version have you updated the window version?
Huynhthinh
This error code is usually encountered in beta window updates
StephanyR
Windows now is on the latest update (not beta).
I should wait for another update?
I tried to solve the problem in many ways but I couldn't...
sdWer
Here is my system information.
Same problem,not about beta version of Windows,it's intel WIFI driver problem or Windows problem.
David_G_Intel
Hello @StephanyR
Thank you for posting on the Intel️® communities.
Please share with us the  Intel® System Support Utility (Intel® SSU)  results:
David G
Intel Customer Support Technician
StephanyR
Thank you. The problem is solved now after the update of windows I reckon.
David_G_Intel
Hello @StephanyR
Thank you for sharing this fix, we are glad to know you found a solution and we will close the thread since it's already resolved.
@sdWer please make sure to follow all the steps posted on this tread, make sure you completed all the Windows updates and if the problem persists, please submit a new question as this thread will no longer be monitored.
David G
