I am using HP EliteBook 840 G6 laptop with the following Windows 10 configuration.
Edition - Windows 10 Pro
Version - 1909
OS Build 18363.1139
SSID: WolfVision
Protocol: Wi-Fi 5 (802.11ac)
Security type: WPA2-Personal
Network band: 5 GHz
Network channel: 108
Link-local IPv6 address: fe80::bc95:ac06:4695:7205%25
IPv4 address: 192.168.2.235
IPv4 DNS servers: 192.168.2.1
Manufacturer: Intel Corporation
Description: Intel(R) Wi-Fi 6 AX200 160MHz
Driver version: 21.110.1.1
Physical address (MAC): A4-B1-C1-97-EC-D0
I am having issue trying to connect to Miracast receiver via Wi-Fi Direct connection. It leeps showing from my Display list that it cant connect. If my Miracast Receiver is connected with LAN, the laptop would then be able to Miracast over MS-MICE.
I have been checking on solution but in vain. This laptop has wi-fi driver and graphics display driver both supported with Miracast.
It is just not working ig connecting Miracast via wi-fi Direct connection.
Please advise.
I would apply Microsoft KB4577063. It may not fix things, but it will not hurt.
And, if I were you, I would update W10 to 2004.
Unfortunately as this is a company laptop, I could not decide on whether to update to Win10 2004.
How do I update to Microsoft KB4577063? Please provide link.
Do you have any other advices to try on?
My Miracast receiver is supporting wifi direct in 2.4G band only.
@ AlHill, I checked that this KB edition is meant for Windows 10 2004 version, which may not be applicable to my Windows OS 1909 build.
My laptop is already on up-to-date updates.
Perhaps one of the Intel support engineers can help you.
I just updated to Windows 10 2004 with OS build 19041.572.
The wi-fi direct connection to my Miracast receiver now works.
This post can be concluded and closed.
Hello Gary-Tay,
Thank you for posting on the Intel* Community.
We are glad to see that the recommendations of the fellow community members helped you to solve the issue, hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Maria R.
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
