Wireless
8536 讨论
Intel Wi-Fi 6 AX200
AnyKey
初学者
2,214 次查看
I have a laptop with only 1 antenna, will this card work with only 1 antenna?
It would be fine for me even if it will be work on 50% of speed limit as for now I have here only WiFi4 card
0 项奖励
5 回复数
AlHill
超级用户
2,206 次查看
Half of it will.
[Windows 11 is the new Vista]
0 项奖励
AnyKey
初学者
2,204 次查看
I just tried to turn off 1 antenna on another laptop, speed dropped from 80 to to 3mb(speedtest dot net), so I decided to ask first.
0 项奖励
AlHill
超级用户
2,203 次查看
You should ALWAYS check with the laptop manufacturer before embarking on such an upgrade.
Also, there are other requirements:
https://www.intel.com/content/www/us/en/support/articles/000005687/wireless/intel-wireless-products.html
0 项奖励
AnyKey
初学者
2,199 次查看
Manufacturer said that there is only 1 wifi5 card was tested with my laptop and it is not sold in my country. So I have no much options here as to buy and try.
0 项奖励
DeividA_Intel
员工
2,131 次查看
Hello AnyKey,
I would like to let you know that if you are planning to install the Intel® Wi-Fi 6 AX200 (Gig+) on your laptop and replace the wireless card that came preinstalled in your device, you will need to check with the laptop manufacturer for compatibility and instructions.
If the wireless card is not supported by the BIOS it may not work or have a bad performance, I recommend you to check first with the laptop manufacturer before attempting any integration. Also, if you use only one antenna, the wireless card may work but it will not have a good performance.
Deivid A.
0 项奖励
回复
