Wireless
8787 Discussions
Intel Wireless-AC 9260 M.2 on Ubuntu 20.04 LTS
amebah
Hello, some days ago i bought an M.2 9260NGW 802.11ac WiFi + Bluetooth 5.0 card for my HP Elitedesk 800 G2.
I have two operating systems installed on my PC: Ubuntu 20:04..2 LTS on M.2 SDD hard drive and windows 10 64bit (build 19042) on an old SATA hard drive.
The windows disk I've used so far only to perform firmware updates of the motherboard and peripherals and to perform function checks of the various peripherals.
Through Windows I was able to verify that the new wifi card was working properly, the OS has in fact recognized it and I was able to update the drivers directly through "Intell & drive & support assistant".
With ubuntu, however, I can not use the wifi connection.
I'll preface this by saying that I'm not an experienced Linux/Ubuntu OS user, so my skills in analyzing the problem are limited.
Therefore, I tried to follow the directions in this guide:
https://easylinuxtipsproject.blogspot.com/p/intel-wifi.html
the result was only half satisfactory, since within the ubuntu network manager there is, at least, the Bluetooth interface, while the Wifi interface seems not to be detected.
That's it, I'm stuck, I can't sort it out.
thanks for your attention
P.S.
using "lspci" the wireless-AC 9260 was listed
using "sudo dmesg | grep iwlwifi" the wireless-AC 9260 was detected
sig230
Is it installed in a PCIe x1 slot or one of the wider slots?
amebah
The PC is the mini version
there is a specific M.2 PCI slot for WLAN module
you can see here: http://h10032.www1.hp.com/ctg/Manual/c04830607.pdf page 25
as I mentioned, the peripheral works correctly under windows
sig230
I can't tell which type PCIe slot that is from the pictures but I have had an issue with Intel AX200 WiFi cards where they work in a 1x slot but not in a 4x, 8x or 16x slot under Linux but do work in the larger lane slots under windows.
See this thread.
amebah
Uhm... Wonderfull! It's strange the Bluetooth works under linux but the WiFi not I just verified specification on HP website:
M.2 PCIe x4-2230 (WLAN)
sig230
Strange is a good word.  Of course both work under Linux in a 1x slot.  Hopefully Intel will come out with a firmware fix soon.
amebah
Any news, good news?
David_G_Intel
Hello amebah
Thank you for posting on the Intel️® communities. Please test the steps from the article:
https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html
If the issue persists, let us know to continue with the investigation.
David G
Intel Customer Support Technician
amebah
Good morning.
I've already used the drivers/firmware on the page you mentioned in the past weeks without success.
My needs have led me to decide to buy another wifi card, specifically, I bought a 8260 socket M.2
this card works correctly with both windows and ubuntu 20.04 LTS
the problem of the 9260 model with linux therefore continues to remain
Thank you for your attention
David_G_Intel
David G.
David_G_Intel
Thanks for the update, please let us know if you'd like to continue troubleshooting because there are some reports that must be provided via email.
David G.
David_G_Intel
David G.
