Wireless
8552 Diskussionen
The description for Event ID 7021 from source Netwtw12 cannot be found.
DenimPirate
Einsteiger
75.004Aufrufe
A lot of people seem to be having this issue with the Intel(R) Wi-Fi 6E AX211 160MHz adapters, and so am I.
Examples of other posts about this issue:
Every so often, usually when I'm usuing a more-than-usual amount of bandwidth (streaming video for example), wifi cuts out. I have to disconnect and reconnect from the router to fix this.
This happens to no other devices on the network, and happens no matter what network I am on.
When this happens, I get events in the event viewer such as:
The description for Event ID 6062 from source Netwtw12 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\NDMP2
The message resource is present but the message was not found in the message table
I have searched through so many psts of people saying the same thing, but there appears to be no conrete resolution for anyone.
I've been having this issue for weeks/months, and it can happen multiple times per hour. It's ridiculous. I am completely unable to do anything.
I have even tried buying a brand new Wi-Fi adapter, the Intel(R) Wi-Fi 6E AX411 160MHz. I thought buying a new adapter would fix the issue, but no. Exact same thing, except now the event is from Netwaw12 instead of Netwtw12.
The description for Event ID 7021 from source Netwaw12 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
Since these devices both use the same driver, it does indeed appear to be a driver issue.
I tried rolling back to earlier versions of the driver for these devices, but no joy.
PLEASE can someone help at all? I'm at a complete loss.
18 Antworten
innerman98
Einsteiger
74.991Aufrufe
Hello, I also have the same problem, and plus, the Bluetooth connection is also lost from my case.
I am using Microsoft Surface Pro 9 with Windows 11 Pro,
and the latest Intel WiFi driver and the Bluetooth driver couldn't solve the problem.
(WiFi : 22.220.0.4 dated 29Mar2023 & Bluetooth : 22.210.0.3 dated 08Feb2023)
From the event viewer, it goes like this.
Every a few seconds, it makes info log with Event ID 7025 & 7026.
And in about every 10 minutes, there are error logs with Event ID 5002 & 5005.
And sometimes, warning log with Event ID 6062.
Also, randomly info log 5032, 7002, 7010 & 7017.
(I attached the event log)
And also, the Windows crashes with bluescreen almost once a day.
Though I don't have an evidence that the crash is caused by this issue, this is my best guess for the crash.
Yesterday, the WiFi & Bluetooth are just gone crash and couldn't get back even after a few times of hard reset.
I managed to make it back to work by changing the SSD and back.
I am using Mikrotik RB4011 & CRS109, which has 2GHz & 5GHz with B/G/N & AC.
Hugo_Intel
Mitarbeiter
74.932Aufrufe
Hello innerman98
Thank you for posting.
Please check my previous post and provide the log file from the Intel® System Support Utility.
Hugo O.
innerman98
Einsteiger
74.899Aufrufe
Hello, Hugo,
I attached the system log from SSU.
Please note that I rolled back the drivers,
From
to
WiFi : 22.150.3.1 dated 04Aug2022
Bluetooth : 22.150.0.6 dated 30May2022
And now I am getting event messages about netwtw10 instead of netwtw12,
however, the system is so much more stable without bluescreen or network/bluetooth drop off.
Hugo_Intel
Mitarbeiter
74.853Aufrufe
Hello innerman98
Based on the official Microsoft support site, the driver version 22.150.3.1 is the one recommended for this system. So we would advise you to stay in that driver version as it is the one customized for the specific hardware.
Hugo O.
Hugo_Intel
Mitarbeiter
74.933Aufrufe
Hello DenimPirate
Thank you for posting on the Intel Communities. I am sorry you are experiencing issues with random disconnections on your Intel® Wi-Fi 6E AX211.
We would like to get the hardware information from your system before providing any recommendations. Please create a log file with the Intel® System Support Utility and attach it to your response.
Hugo O.
DenimPirate
Einsteiger
74.924Aufrufe
Hugo_Intel
Mitarbeiter
74.852Aufrufe
Hello DenimPirate
I did not see the adapter on the log file that you shared with us. Did you have the wireless adapter connected at the time of generating the report?
Also, please let's try using the latest driver version recommended by your system manufacturer which is 22.190.0.4, install the driver through clean installation and let us know the results.
Hugo O.
Hugo_Intel
Mitarbeiter
74.704Aufrufe
Hello DenimPirate
I hope you are doing fine.
Hugo O.
Hugo_Intel
Mitarbeiter
74.625Aufrufe
Hello DenimPirate
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
sMorrison
Einsteiger
63.842Aufrufe
Hugo O.,
I am having the exact same issue as those above.
1) Bluetooth Drop off.
2) System Crashes
3) Netwtw12 events (I don't even use wireless. My house is completely hardwired)
The description for Event ID 7025 from source Netwtw12 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
\Device\NDMP3
I have attached the SSU Report and a pic of the system events before the CRASH (Blue screen) .
Scott
Ploegske
Einsteiger
63.269Aufrufe
Hello. I came here because I noticed my event log is flooded with notifications from Netwtw12, for which a solution would be nice.
Furthermore I read about Wifi connection issues. Are they still present? I don't use Wifi at home, but I will take my Surface Pro 9 on a holiday, so it might be good to know what's happening.
I read some people have reboot issues. I used to have that prior to a Windows update last November. Now everything seems fine. My current driver version is 22.230.0.8, coming from 22.160.0.9
GContente
Einsteiger
62.907Aufrufe
Hello all,
We are experiencing random WiFi disconnections on our corporation. So far we have seen that disconnections happens on Surface laptops with Intel chipsets.
In this case we have Surface laptop 5 with Intel(R) Wi-Fi 6 AX201 160MHz and Surface laptop studio with Intel(R) Wi-Fi 6 AX200 160MHz. We have identified that every time a user reports a wifi disconnection we see on the WLAN report that the network was disconnected by the user when it wasn't. At the time of disconnection we also see the same netwtw12 log in system events. For the Intel(R) Wi-Fi 6 AX201 160MHz the driver version is 22.250.1.2, which is fairly recent. I suspect that from what i have searched on the internet this issue wont go away even after updating the drivers.
RobsonCarvalho
Einsteiger
60.841Aufrufe
I had the same issue until I stopped and disabled all Killer services using services.msc. It's been two days since the last disconnection.
My driver version is 22.250.1.2 - Windows 11 23H2
Netadmin
Einsteiger
55.377Aufrufe
we are also having the same issue,  was the issue resolved after you disabled the Killer service? thanks
Gongjimin
Einsteiger
53.802Aufrufe
I had the same issue.
My driver version is 23.40.0.4 - Windows 11 23H2
The event source is "Netwtw14 " and the ID is 7021 or 7003.
Yesterday, I moved my notebook to and other place, the Wi-Fi Connection was OK, but I could not ping to the gateway. After about a minute, it‘s find again.
I found two event with ID 7021 and 7003.
I found some description of the ID.
<https://windowsforum.com/threads/windows-suspicious-event-logs-and-restart.250141/>
7021 - Connection telemetry fields and analysis usage
7003 - Roam Complete
Henrique_sn
Einsteiger
50.617Aufrufe
Well, since no one from support can explain or find a definitive solution. After searching on the internet, I found some comments and came up with the following solution to this problem on my machine, and since then, I haven't had any Wi-Fi issues.
I went to the network card properties and made the following adjustments.
If it doesn't work, try configuring it with other bands. See attached screenshot.
danberger
Einsteiger
48.962Aufrufe
I am having the same exact issues with all the errors and am convinced it's what's causing a critical BSOD crash daily.
JGFMK
Einsteiger
47.514Aufrufe
These events are also appearing in the Event Viewer in a combo of 2 info, 1 warning for netwaw14 too.
Recurring System Event_IDs 7021(Info),7003 (Info), 6062 (Warning)Recurring System Event_IDs 7021(Info),7003 (Info), 6062 (Warning)
Network Adapter is Intel Wi-Fi BE200 320MHz - on a Razer 18 (2024). See my posts here.
I rolled system back to Factory settings twice, and looked at shipped driver vs the one with Intel Software Component 2408.5.4.0
I made sure no Windows updates for cumulative packs or drivers were installed.
I get a BSOD stop code: DRIVER_POWER_STATE_FAILURE
if I download the Intel Software Component 2408.5.4.0 then apply the cumulative Windows monthly update 2024/05 or 2024/06.
Update 1:
I think this issue may be down to Nakama MP (a multi-player platform service). I use Paradox Interactive with both a PS5 and PC.
See this post.
Update 2:
Today Intel provided me an update. Be sure to check this out. It seems to have fixed my constant Stellaris disconnects.
https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
Use the 'get started' button rather than the download if the series of Network Adapter Driver doesn't correspond to your system.
After running the exe, be sure to reboot. I got no BSOD this time around. Looking good so far - longest period I've been able to play Stellaris unimpeded by logged out messages.
Antworten
