Wireless
8554 Discussions
Why doesn't my Intel BE200 support Wi-Fi 7 in Linux?
ningl
May I ask why my Intel BE200 doesn't support Wi-Fi 7 in the Linux environment? My Linux kernel version is 6.14.0. The regulatory information is as follows, and please see the attachment for the ssu.sh check results. Could you please help me take a look? I urgently need to use Wi-Fi 7 in my Linux system.
global
country 00: DFS-UNSET
(755 - 928 @ 2), (N/A, 20), (N/A), PASSIVE-SCAN
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
country CN: DFS-UNSET
(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5490 - 5510 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5510 - 5530 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5530 - 5550 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5550 - 5570 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5570 - 5590 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5590 - 5610 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5610 - 5630 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5630 - 5650 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5735 - 5755 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5755 - 5775 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5775 - 5795 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5795 - 5815 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5815 - 5835 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
JedG_Intel
Hello ningl,
It appears that you're having issues connecting to Wi-Fi 7, and I understand how important this is to you. To address the issue effectively, kindly share the information below.
1. Was this working fine before?
2. Are you able to utilize Wi-Fi 7 with Windows environment?
3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
4. Is this a laptop or desktop system?
5. What troubleshooting steps have you performed so far?
Best regards
Jed G.
ningl
==>Never worked properly;
==>Has not been tested in a Windows environment;
ubuntu pre-installed
pi5
no
JedG_Intel
Hello ningl,
Thank you for sharing all this information. Let me just clear this out, is the BE200 pre-installed on the system or was this installed recently?
Additionally, please try to install the latest Kernel version 6.16 at The Linux Kernel Archives and the latest firmware at Firmware git tree.
Firmware versions:
- iwlwifi-gl-c0-fm-c0-1001
- iwlwifi-gl-c0-fm-c0.pnvm
If you have any questions, please let me know.
Best regards
Jed G.
