Wireless
8514 Discussions
Wi-Fi 6 disappeared after upgrade Windows 11 to 24H2 from 23H2
SignFinder
Débutant
9 918 Visites
Hi team,
I upgraded Windows 11 Professional from 23H2 to 24H2 on my laptop Dell with Intel AX201 card on-board.
And found that It stopped to connect to router via 802.11ax (Wi-Fi 6) and started to connect only via 802.11ac (Wi-Fi 5).
I have updated drivers to 23.100.1 https://www.intel.com/content/www/us/en/products/sku/130293/intel-wifi-6-ax201-gig/downloads.html
but it was not helpful.
How to restore  WiFi6?
It looks like certificate, what was used to sign WiFi 6 drivers - was revoked in Windows 24H2.
0 Compliments
19 Réponses
DeancR_Intel
Modérateur
9 733 Visites
Hi SignFinder,
Thank you for posting in the Community!
Please share more details about the issue so I can assist you effectively.
Have tried a roll back to a previous driver version for testing?
Is this a laptop or desktop system?
I suggest doing the steps here in this link:
Wi-Fi Adapter Is Disabled or Is Not Working
Dean R.
0 Compliments
SignFinder
Débutant
9 721 Visites
Hi @DeancR_Intel
This is laptop Dell Latitude 5521.
I tried several Intel Wifi driver versions and no any version works with WIFI6 when Windows 10 24H2 installed.
But if I revert Windows version to 23H2 - connectivity via Wifi6 restoring with any driver version.
How to achieve connectivity with WiFi 6 (802.11ax) + Intel AX 201 + Windows 24H2?
0 Compliments
DeancR_Intel
Modérateur
9 649 Visites
Hi SignFinder,
This is well acknowledged, I suggest you try the recommended settings for further compatibility:
Recommended Settings for 802.11ax Connectivity
Let me know if the issue still persists.
Note: Please note that this is an OEM device, so I will try to assist you with general troubleshooting steps. However, if the issue persists, you will have to contact the Original Equipment Manufacturer of your device. Your device manufacturer may have altered features, incorporated customizations, or made other changes to some components for better compatibility with your system.
Dean R.
0 Compliments
SignFinder
Débutant
9 620 Visites
Yes, issue still persists.
I have made clean installation of Intel WIFI drivers too and check recommended settings.
Let me highlight that:
1. WIFI 6 on Windows 11 23H2 works well with several versions of Intel WIFI drivers.
2. Another devices works well with WIFI 6 when they connect to the router.
3. Now two (laptop with Intel AX201 and another desktop with AX200 cards onboard) devices stopped to connect to the router via 802.11ax after their upgrade to Windows 11 24H2.
4. I use official Intel WIFI drivers, not manufacturer drivers.
0 Compliments
DeancR_Intel
Modérateur
9 596 Visites
Hi SignFinder,
This is an acknowledgement message for your case, do please wait as this concern will be investigated internally to be able to provide a resolution to your request. I will get back to your once I have the necessary information.
Dean R.
0 Compliments
DeancR_Intel
Modérateur
9 475 Visites
Hi SignFinder,
To further investigate the issue, please follow these steps:
Download and Install the Latest Wireless Driver:
Clarify Band Connectivity:
  • Confirm whether you are unable to connect to the 6GHz band. According to the laptop specifications, only the 2.4GHz and 5GHz bands are supported (refer to page 15 of the manual Latitude 5521 Setup and Specifications).
Router/Modem Information:
  • Please provide the make and model of the router/modem you are using to connect the computer.
Obtain SSU Logs:
  • Obtain the SSU logs of the system to fully check the system configuration.
  1. Download and launch SSU.exe.
  2. Check the box for "Everything."
  • When the scanning is complete, click "Next."
  • Click "Save."
  • Please send the saved file to us.
For additional troubleshooting, you can refer to the following articles:
Dean R.
0 Compliments
SignFinder
Débutant
9 360 Visites
Hi DeancR,
Sorry for the delay with the answer.
I have installed latest Dell WIFI drivers version 23.90.0.2, A47 and nothing changed - 802.11ac available only.
My router is Zyxel Keenetic Ultra and there is at lest Google Pixel 9, what connects to this router via 802.11.ax successfully.
What about Dell specification - I can only confirm that this laptop was able to connect to this router via 802.11ax before it was updated to Windows 11 24 H2 from 23H2.
SSU logs are attached to this message.
0 Compliments
DeancR_Intel
Modérateur
9 380 Visites
Hi SignFinder,
Dean R.
0 Compliments
DeancR_Intel
Modérateur
9 229 Visites
Hi SignFinder,
I appreciate your cooperation and efforts for providing this information. I will further check this internally and get back to you once I have the information you will be needing.
Dean R.
0 Compliments
DeancR_Intel
Modérateur
9 171 Visites
Hi SignFinder,
Thank you for providing the requested information and logs. Based on my investigation, I recommend reaching out to Microsoft Support for further assistance with this issue. They have the necessary tools and expertise to help resolve the crashes you're experiencing.
You can contact Microsoft Support through their official website: Microsoft Support
I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
0 Compliments
SignFinder
Débutant
9 129 Visites
Thanks for your attention.
It is a pity, because Microsoft already declined to research it and asked to go to laptop manufacturer.
In result - closed circle and nobody is responsible for this problem.
0 Compliments
LeonWaksman
Super utilisateur
9 097 Visites
0 Compliments
SignFinder
Débutant
8 052 Visites
Hi @LeonWaksman
Thanks for your idea. But unfortunately Memory Integrity Protection is already disabled.
To be honest - I've resigned myself to the fact that no one will fix this problem - I'll live with WIFI 5.
0 Compliments
n_scott_pearson
Super utilisateur
9 068 Visites
I suggest you do a full and proper clean install. Here is the process to follow:
  1. If you haven't already, download - but do not install just yet - the latest Bluetooth and Wireless driver packages for your adapter. Here are the current links for downloading these drivers: Wireless: https://www.intel.com/content/www/us/en/download/19351 and Bluetooth: https://www.intel.com/content/www/us/en/download/18649.
  2. Most important! Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable. Note: This Wireless disable *must* be of type that will persist (i.e. stay disabled) across reboots.
  3. From the Apps & Features applet, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip forward to Step 6.
  4. Uninstall each instance of Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth that is present. When prompted, choose to "Discard Settings".
  5. Manually reboot your computer, keeping Internet access disabled throughout.
  6. From the Device Manager applet, check the Network Adapters section for an entry for Intel Wi-Fi 6 AX201, and check the Bluetooth section for an entry for Intel Wireless Bluetooth that has an Intel driver associated with it. If neither is the case, skip forward to Step 12.
  7. Right click on the entry for Intel Wi-Fi 6 AX201 and select Uninstall Device. In the dialog that is then presented, choose to (checkmark) Delete the driver software for this device.
  8. Repeat step 7 until the option to Delete the driver software for this device is not offered (i.e., is greyed out).
  9. Right click on the entry for Intel Wireless Bluetooth and open its properties. If it has an Intel driver associated with it, then uninstall it, choosing to (checkmark) Delete the driver software for this device.
  10. Repeat step 9 until the option to Delete the driver software for this device is not offered (i.e., is greyed out).
  11. Go back to Step 5.
  12. Install the downloaded Bluetooth driver package you downloaded earlier (my rule: always install Bluetooth first).
  13. Install the downloaded Wireless driver package you downloaded earlier.
  14. Manually shutdown and reboot your computer.
  15. Reenable Internet access. Restore Ethernet cable and/or reenable wireless.
  16. Test.
Note: It sometimes takes multiple uninstall (and reboot) cycles to clean out the old installations, so don't give up on the process. If you get to, say, 10 cycles, stop there and attempt the installation of the latest drivers.
Hope this helps,
0 Compliments
Rick14
Débutant
4 629 Visites
Try using Intel Driver 22.45.1.1   I had the same problem with my XPS and this driver worked.
0 Compliments
rpfrisbe
Débutant
934 Visites
This problem seems to be the start is being set to 6.  Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WinHttpAutoProxySvc\ and set Start to 2 (2 worked for me)
This seems to only apply to the 210 and 211 so far.
0 Compliments
wc2468
Débutant
765 Visites
What does 2 do?  as I understand it 4 is disabled, and 3 is enabled.
0 Compliments
LeonWaksman
Super utilisateur
750 Visites
Set 3 to Start manually, set 2 to Auto Start.
Leon
0 Compliments
rpfrisbe
Débutant
257 Visites
Tracked down the issue a little further, and there is a fix for the WPAD vulnerability in windows, so it appears that the AV vender recommendation was to set a policy which set that key to 4.
When Windows gets updated, then stuff breaks.  Here is an article at Microsoft about the issue.
Windows 11 24H2 Network Breakage: DHCP, WPAD, and WcmSvc Mitigations | Windows Forum
0 Compliments
Répondre
