Wireless
8513 Discussions
Wireless-AC 7265 5GHz not working in windows 8.1
JBerg14
Hello
Running Windows 8.1 (x64), tried drivers 17.13.11 and 17.1.0. The problem is, i cannot see any 5GHz networks using windows list of wifi networks or SSID scan tool (inSSIDer). I can see multiple SSID's including my own on the 5GHz band on my other devices. I just got the 7265 card yesterday.
I have tried a bunch of things, including a fresh install of windows and the stuff in the support section on intel website (adapter settings for optimal performance etc). Nothing works!
netsh says my card has "802.11a" and "802.11ac" capability in windows, which seems fine.
It almost seems like there is something turning off the 5GHz radio on the card in windows.
Since the card is new, i thought there might be a hardware issue, i.e. 5GHz radio broken.
However i tried booting from a linux live USB stick, in this environment i can see 5GHz networks, i can connect to my own 5GHz network and i get AC link rates (400-800mbit) and high transfer speeds (100mbit+). This was on ubuntu 14.04LTS. So there should be no hardware failure or hardware incompatibility issue.
Anyone have any tips? Is there any kind of power saving mechanism (or similar) in windows that's capable of turning off only the 5GHz radio? The 2.4GHz radio works fine.
RColl6
I've just struck a similar problem with a Lenovo ThinkPad T550, and a DLINK DAP-1650 Access Point.
The Thinkpad contains an "AC 7265" wireless adaptor, which supports 802.11a/b/g
The DLINK supports: 802.11a/ac/n.
With everything on default settings, it wouldn't connect at 5GHz, but would at 2.4GHz.
InSSIDer could see the 5GHz signal, and said it was using 802.11n.
I found I could force it to connect by doing either (or both) of the following:
[1] On the PC, change the adaptor's "Wireless Mode" from "802.11 a/b/g" to "802.11a"
(which will prevent you from connecting to 2.4GHz access points)
or
[2] On the WAP, change the "Wireless Network Settings (5 GHz)", "802.11 Mode" setting from "Mixed 802.11ac, 802.11n, and 802.11a" to "802.11ac only"
(i.e. the only setting which does not include "802.11n")
ffabi2
I have an Intel NUC Skylake with a 8260 wifi chip. right after installing the driver, 5GHz worked, until I restarted my PC, since then I'm on 2,4GHz.
For some reason 5GHz connected like one week ago, I thought it's because of the Windows Update and it's finally fixed, but yesterday I got thrown back to 2,4GHz I tried the driver from 12/22/2015 and the current 1/5/2016.
HBreh1
I have the same problem with the latest Skylake NUC and the AC 8260 chip and Windows 10. Linux finds 5Ghz networks.
Edit: So far, BIOS reset worked for me.
ffabi2
I guess I got rid of that problem. try the new bios update and if your pc dont find a 5ghz connection, just restart until it find it.
I didn't lost the 5ghz connection for a week now.
MMina3
I have similar problem like in post # 31
My vendor said that I have AC 7265.
My Windows 10 is not agreed to that and shows N 7265
On Lenovo website after typing serial number of my laptop shows: "Intel Wireless 7265 (2x2) AGN"
Can You help me and tell me what type card do I have finally ?
Big thanks!
intel_admin aleki_intel
