i have desktop that didnt have blue tooth , i downloaded b t driver and still cant get it to work
what can i do?
eMachines EL1358G
Devices and Drivers
AMD Athlon™ II X2 220 Processor
Microsoft Basic Display Adapter
Realtek High Definition Audio
TAP-NordVPN Windows Adapter V9
NordLynx Tunnel
NVIDIA nForce Networking Controller
3 GB
Generic- Multi-Card USB Device
Hello brett069,
After checking your post I could not find any wireless hardware, I would like to know if you have an Intel® Wireless Adapter, you may want to check with the system manufacturer (OEM) to check if your system should include Bluetooth capability.
If you have an Intel® Wireless Adapter, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
- Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Are you having issues with Wi-Fi, Bluetooth, or both?
3. Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
4. Were you able to have your wireless connection in a normal/expected performance before? If yes, did you make any changes before the issue started?
Sebastian M
Hello brett069,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
Hello brett069,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Sebastian M
