Greetings,
I installed Intel MPI library and Toolkit once, which was very successful. However, I realized I installed them into a wrong place and uninstalled them from C:\Program Files (x86)\Intel\oneAPI\Installer. After that, I tried to install MPI and Toolkit again, but both of them did not work with the same reason: An error has been encountered during the installation process. ...... Failed to load package. Try to download full installer package from remote source again and re-start installation.
I downloaded many times from Intel Offical website and did not work, always with the same error.
Here are the log files.
Thank you!
Hi Jingkun, Could you please share the below details with us?
- Exact version of Intel® HPC Toolkit or Intel® MPI Library (in case you're using Stand-Alone Version).
- Version of Microsoft Visual Studio installed along with it's build version.
- OS build on which you are installing the product.
- Other versions of Intel® Parallel Studio XE or Intel® oneAPI already installed on the system.
- Is the installer an online or an offline package?
To assist you further, we would require these details.
Hi Vipin,
The version of HPC Toolkit is 2024.0.1.35_offline, and the version of intel MPI library is 2021.11.0.49512_offline, which is the stand-alone version. I tried to run the installation again and got the same errors, so I attached the screenshot of those error as "MPI.jpg" and "HPCKit.jpg".
I am really new in these things, I did not find Microsoft Visual Studio in my PC and am not sure whether it exists or not. But I have many different versions of Microsoft Visual C++. All the versions of them I attached as "Microsoft Visual C++.jpg"
OS version I guess is 22H2 (19045.4046)
It's weird that my replied are not posted successfully
HPCKit is 2024.0.1.35_offline
MPI is 2021.11.0.49512_offline
My OS is 22H2 (19045.4046)
I did not find Microsoft Visual Studio in "Programs and Features", but I have many different versions of Microsoft Visual C++, I will post them in the attachment.
I did not find Intel® Parallel Studio XE or Intel® oneAPI in "Programs and Features".
Thank you!
And here are some attachments for the error screenshots of installations.
And also the versions of Microsoft visual c++, I uploaded a wrong picture in my last reply.
Thank you!
Thank you!
It is super weird that I can send anything with my OS build version.
Here is the screenshot.
Hi Jingkun, we would like to inform you that the tested and validated Microsoft Visual Studio is Version: 2022 17.7.5 for all the latest Intel® Toolkits. Kindly follow the below troubleshooting steps to perform the installation:
- Open the Control panel and click on Uninstall a program below the Programs box.
- Find "Microsoft Visual Studio (existing versions)" then click the right button and uninstall.
- The uninstaller program will be open then click on remove and select the next procedure.
- Kindly visit the below link to find the steps with InstallCleanup.exe to make sure a Visual Studio version is completely uninstalled.
- Link: https://learn.microsoft.com/en-us/visualstudio/install/uninstall-visual-studio?view=vs-2022#remove-all-with-installcleanupexe
- Once the uninstallation is complete, we suggest you download the compatible Visual Studio version (i.e., Visual Studio 2022 17.7.5 ).
- Please note, that our engineering team has tested and documented the compatible Visual Studio versions and their build numbers for integration with the suite & toolkit versions.
- Intel® Compilers Compatibility:
- Make sure you select the 'Desktop development with C++' component while installing Visual Studio.
- Once Visual Studio 2022 Version 17.7.5 is successfully installed, you can proceed with installing Intel® oneAPI Math Kernel Library (oneMKL) Offline from the below link:
Hi Vipin,
Thank you for your help! I tried to follow all these instructions and install Intel® oneAPI Math Kernel Library (oneMKL) Offline from that link, but I met the same problem with previous installation error.
Here are the error files. I guess probably the reason of installation fails is not from Microsoft Visual Studio because I believe I did not have it in my PC before installation. Microsoft Visual Studio does not influence anything, the main problem could be that some error occur when I use the installer.
For the installer of MPI, HPCKit, and oneMKL, I think the reason could be the same.
Hi Jingkun, we have sent you a private message. Kindly check your community inbox.
Hi Jingkun, unfortunately, we were unable to hear back from you.
If you have any further queries, please post a new question, as this thread will no longer be monitored by Intel®.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
