- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I just installed the latest Robotics SDK on Windows 11 WSL2 running Ubuntu. Everything seemed to install correctly.
I ran:
source /opt/ros/humble/setup.bash
ros2 topic list
and got the following error:
usage: ros2 [-h] [--use-python-default-buffering] Call `ros2 <command> -h` for more detailed usage. ...
ros2: error: argument Call `ros2 <command> -h` for more detailed usage.: invalid choice: 'topic' (choose from 'control', 'daemon', 'extension_points', 'extensions', 'node', 'param', 'pkg', 'run', 'service')
When I run: ros2 -h
Returns:
ros2 is an extensible command-line tool for ROS 2.
options:
-h, --help show this help message and exit
Do not force line buffering in stdout and instead use the python default buffering, which
might be affected by PYTHONUNBUFFERED/-u and depends on whatever stdout is interactive or not
Commands:
control Various control related sub-commands
daemon Various daemon related sub-commands
node Various node related sub-commands
param Various param related sub-commands
pkg Various package related sub-commands
run Run a package specific executable
service Various service related sub-commands
Notice: There is no topic listed in available commands.
Have you seen this error before? No matter what subcommand (even pub) that I issue ros2 topic, ros complains that the command topic is invalid.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
ros2 launch commands returns the same error.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Turtlesim runs fine but still cannot run ros2 topic list on another window.
Same error:
ros2 topic list
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I reinstalled ros humble and my issue is now resolved.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Glad to know that your issue is solved.
Intel will no longer monitor this thread. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
