FPGA Intellectual Property
6663 Discussions
LVDS SERDES IP with cascaded downstream PLL
MichaelB
Nouveau contributeur I
1 450 Visites
I have a question about cascaded downstream PLLs.
I created a LVDS SERDES core with internal PLL.
I selected an additional output to use this clock as a PLL refclk input for my downstream PLL.
Is this a valid connection to get the clock from SERDES as upstream PLL to connect a downstream PLL?
I've connected the locked-output to the permit_cal-input of the downstream PLL.
Furthermore I've connected the additional clock output to the adjpllin-input.
Downstream PLL has High-Bandwidth setting, of course.
During Fitter (Plan - stage) I receive this critical warning:
Critical Warning: Could not find PLL ref clock that feeds io_pll|stratix10_altera_iopll_i|s10_iopll.fourteennm_pll|outclk[0]
Furthermore I saw this info:
Info(18386): io_pll|stratix10_altera_iopll_i|outclk[0] (1824 fanout) drives clock Sectors (4, 3) to (6, 3)
and checked the PLL Usage Summary for this downstream IO PLL where the pll_cascade_in is detected correctly:
-- PLL_CASCADE_IN source:
rx_lvds_serdes|core|arch_inst|pll_inst|internal_pll|stratix10_altera_iopll_i|s10_iopll.fourteennm_pll
I really want to take care that there is no issue in the connection and try to avoid any critical warnings in my design.
Could you maybe help me to find the reason for this critical warning and how to avoid it?
Is there any issue in my connection from SERDES LVDS (internal PLL) to downstream IO PLL?
 Michael
0 Compliments
EngWei_O_Intel
Employé
1 436 Visites
Hi Michael
Thanks for your inquiry.
In general, we don't use output clocks from LVDS SERDES IP as the purpose to cascade another PLL. Are you creating your design using Platform Designer?
In Platform Designer, I don't see a valid connection from output clocks of LVDS SERDES IP to the adjpllin of the cascaded PLL, in fact, the connection from cascade_out of an upstream PLL to the adjpllin of downstream PLL is available.
Eng Wei
Voir la solution dans l'envoi d'origine
3 Réponses
EngWei_O_Intel
Employé
1 437 Visites
Hi Michael
Eng Wei
MichaelB
1 434 Visites
Hi! Thank you for your reply!
Yes I was using the platform designer. I just thought I can connect a downstream PLL due to info in SERDES LVDS IP that a downstream PLL should have High Bandwidth setting. I assumed I can connect an additional outclk to adjpllin and the locked to the permit_cal signal (like general IO PLL cascading).
Now I have created an external PLL which is connected to the LVDS SERDES block and use a cascade-out from external PLL for my downstream PLL.
Using this connection there is no critical warning in my design and fitter result shows all clocks which I have configured.
Michael
0 Compliments
EngWei_O_Intel
Employé
1 416 Visites
Hi Michael
Great that the issue is going away and I hope this suit your design needs. I am currently transitioning this case to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
0 Compliments
Répondre
