FPGA Intellectual Property
6670 토론
NIOS hanging when reading a register from JESD204B core
SZack
Partner
1,317 조회수
I have a customer experiencing an intermittent issue with the NIOS control of the JESD204B core. On certain modules (no apparent difference in hardware) the NIOS will hang waiting on a return from a register read inside the JESD core. The function "IORD_32DIRECT" is called, and it never returns - do you have any idea what could be causing that to happen?
0 포인트
1 응답
Nathan_R_Intel
647 조회수
Hie,
Its not an expected behavior for NIOS to hang while waiting on a return from a register within our IP core. Please check if the timing constraints are specified correctly and check for timing violations. Either than timing, also check to ensure all clocks and resets related to NIOS and JESD IP are behaving correctly.
Nathan​
0 포인트
응답
