FPGA Intellectual Property
6672 Discussions
PLL Reconfiguration IP in Arria 10 Avalon Mapping
VN0001
We are using Arria 10 Soc in our design. In that PLL Reconfig IP is used to dynamically changing the PLL outclock and Phase shift. So we implemented and connected the Avalon slave bus to The HPS light weight bridge as per An 728. Automatically it generated the address map also for this, But we are not able to acess from HPS.. Kindly help this to resolve this issue. attached is the snap for your reference
sstrell
When you say you are not able to access the IP, what's happening or not working correctly? Reads or writes of the registers failing?
VN0001
Hello sstrell,
We are not able to write and read to the register space of that ip. No hanging and all..
Venkatesh babu.N
Rahul_S_Intel1
Hi , Kindly provide in details. How you are not able to access HPS.
VN0001
Hello sree, The forum site is not available. We are not able to write and read to the register space of that ip. No hanging and all.. Thanks with regards, Venkatesh Babu.N Get Outlook for Android<https://aka.ms/ghei36>
Rahul_S_Intel1
Kindly provide the procedure, how you read and write in the IP, is it through system console or through image or doing any partial reconfiguration
