FPGA Intellectual Property
6673 Discussions
RSFEC decoder is not generating output
APPU_appu
we are generating RSFEC decoder IP  we are providing required signal as input but we are not able to see output in modelsim
SengKok_L_Intel
This is suggested to use the example design to run the simulation. You can generate the example design from the IP GUI. From the generated example design, there is a simulation_scripts folder. You can refer to the script over there to run the simulation.
\rs_ii_0_example_design\simulation_scripts
Regards -SK
SengKok_L_Intel
Regards -SK
APPU_appu
Thank you @SengKok_L_Intel  issue solved
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
