FPGA Intellectual Property
6669 Discussions
is it matrices supported by Altera DSP builder
Hi guys.
I have 64x64 matrices in my design. I want to convert it into HDL code. Can Altera DSP builder convert this matrix into HDL code? Thanks in advance.
No matrix does not supported by altera.........u have to send each matrix element one by one.......
Related to this, I am trying the LUT with Advanced DSP Builder blocks. I want the output to be a vector, and the documentation says vectors can be output, but this doesn't seem to work!? Is this a documentation error, and can't I use LUT for a vector output (I've set the value in the parameter block to a matrix)?
I tried the example, which I found after searching the dspba directory. Apparently, to get a four-element output vector from LUT, you need to supply the input to LUT as a vector of 4 elements. I had expected to supply just the row index of the vector. For matrices, the LUT block acts like (in this case) 4 independent LUTs, one for each output component. So, thanks Altera for the examples, next time I know where to look!
Yes, there is many useful example that come with DSP builder. In order to convert the design into VHDL, you have to use the blackest from the DSP builder library. Keep in mind that, the design flow of Advance and standard blackest is difference.
