Can someone send me a link to where I can find the footprint and pin connection for the 10M02SCE144C8G, as I need to do a PCB layout and I need to know what pins to connect up.
Sorry to let you know that Intel FPGA do not provide support for PCB footprint symbols for FPGA and CPLD device families, similar to configuration devices.
However, we will continue the support by providing the schematic symbol which you can download from the link below. You could have the schematic symbol in .olb format from the link below:
Here is the document for Intel® MAX® 10 FPGA Device Family Pin Connection Guidelines: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf
Thank you.
Here what am looking for:
But for the 10M02SCE144C8G, so therefore I am now using the EPM7128 as I have mode up the required PCB foot print, and it is able to work with 5v TTL directly, which is a big advantage in this application. As for the *.olb file, all I get is unknown file format and it has no use to me for PCB development work.
Looking to verify if the following marking is correct for this part number.
