Currently, I passed all setup, hold, recovery and removal timing within the FPGA with constraint all paths and I/Os, but my I/O through GPIO portion did not passed the timing. Do you have any recommandation or hint about this topic in FPGA design? It is a great if your suggestion can help me to pass I/O timing.
Again Thank you in advance!
-Fred
- « Previous
- 1
- 2
- Next »
HI YY,
I see. Thanks for your quick response. Currently I add new commands in qsf file as following as:
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataL[2]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataL[0]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataH[3]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataL[1]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataL[6]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataH[6]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataH[2]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataH[0]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataL[3]"
set_location_assignment LAB_X149_Y70_N0 -to "image_sampling:module_image_sampling|adc_sample_top:adc_sample_inst|adc100mhz_interface:adc_sample|sig5Adc0Bank1DataH[1]"
The timing report is still has [cid:cdf2b8ff-bd8b-41ee-9023-b788567e7ff3]
The floorplan placement which matches constrain as following as
[cid:74445102-84c9-44b8-a9af-dc4882e6e8be]
Before I put above constraints, the floorplan placement is as below routing with same report delay, but routing distance cross a lot of LABs comparing above and below placement, so I suspect timing report is wrong. As I did Synopsys ICC2 timing project back three years ago, these distances should have different timing report because net delay has a big difference. Since I/O pads fix the location, you can figure out rest of constrains to do experiments.
[cid:7fd1c7c8-fc24-4aac-9c3e-92c450438757]
I used 10AX027H4F34I3SG device.
Thank you so much!
-Fred
Hi Fred,
Are you attaching something in this thread? I cannot see the attachment. Could you re-attach?
YY
Hi YY,
On. Never mind, maybe system block them.
-Fred
Hi Fred,
Do you have any other questions or help needed?
-YY
Hi YY,
I am pretty smooth to debug this FPGA so far. I only have one question: do you know or ever hear that Altera FPGA can increase sensitivity for the LVDS input pin beside board to change terminator or layout trace width or length. I already turn on LVDS terminator. I ask this question because one of bit_clock signals is too weak that cause miss detect data frequently. Besides, I am fine now.
-Fred
Hi YY,
Oh, I think I might change design architecture to solve this unstable issue in the FPFA if you cannot find a solution in the device side, but I need to do some experiments in the next week to confirm what I thought since I need to solve more important issue in another topic during this design. If you would like to close this case, please do it.
Again thank so much for your support😊
-Fred
You are welcome. 😊
- « Previous
- 1
- 2
- Next »
