My wife uses a B780 plugged in to a PCIE 5.0 slot of a MSI MAG Z790 TOMAHAWK WIFI with 32GB DDR5 ram. The power supply is 1250 watt. Her computer has Windows 11 and the OS and graphics drivers are at latest level.
She runs 3 monitors. After the system is brought out of sleep, there are artifacts, white rectangular boxes, appearing and only on the main #1 monitor. They don't appear in screenshots so I recorded the attached video.
She has been rebooting to correct it but what I discovered is that if I change the refresh rate the issue is corrected. The monitor is a Koorui 24E4 using DisplayPort. It's refresh rate was set to 165 Hz. I set it to 60 Hz. The artifacts went away. I set it back to 165 Hz and the artifacts didn't come back at that time. The other two monitors are always set to 60 Hz.
She said she also noticed artifacts if she leaves an explorer window open and the PC sleeps and is awakened.
Are there any suggestions that will help to fix or prevent this?
Forgot to mention, CPU is i7-13700KF
Hi @imaddicted2u,
- Please provide the SSU log report and share it here so I can review your system's configuration.
- Which specific DisplayPort version is the cable? (1.4, 2.0?)
- Are you using any DisplayPort adapters or hubs?
- What's the exact model of the other two monitors and their connection types?
- What Windows 11 power plan is active?
- Is G-Sync/FreeSync enabled on the primary monitor?
- Does the issue happen with shorter sleep periods (1-2 minutes)?
- Does manually turning off/on the monitor resolve it without refresh rate changes?
- When did the issue first occur?
- Have you made any software or hardware changes to the system recently?
- Have you noticed any signs of overheating in the system?
This appears to be a display signal integrity issue that occurs specifically when resuming from sleep mode, affecting only the high-refresh-rate primary monitor. The fact that changing refresh rates temporarily resolves the issue suggests timing/signal synchronization problems during the wake-up process.
Randy T.
Thanks for the quick reply.
If I hadn't seen it myself and recorded video, I'd say it doesn't happen, at least not every time. I just woke the PC after hours of sleep and the desktop was displayed fine. I put it to sleep for a minute and woke it, desktop was displayed fine. Don't spend a lot of time on this. I'll provide the info so you can take a quick look. I'll reply back if/when it happens again. I'll power cycle the monitor if it happens again to see if it clears the issue.
I don't use the PC, my wife said it happened said this happened all the time but didn't give a frequency or when it started. Obviously that is not the case.
Not using DP hubs or adapters. Other 2 monitors are using the 2 HDMI ports on the B780.
Monitors connected:
Koorui 24E4 is 1080P. Specs say DP is 1.2.so I assume the cable that came with it is 1.2 also (no markings on cable). Freesync Premium is turned on in the monitor menu.
Windows power plan is Balanced.
No SW or HW changes, other than regular Win 11 and driver updates. Maybe some game installs.
No signs of the system heating up. Fans are quiet, never get loud when under heavy load or gameplay.
Hi @imaddicted2u,
Thanks for the detailed information about your display issue. Based on your description of intermittent artifacts during wake-from-sleep scenarios, this appears to be either a driver-related issue or potential hardware problem. Since it doesn't occur every time and seems tied to sleep/wake cycles, we can use specific tests to isolate whether this is caused by software drivers or hardware components.
Here are the troubleshooting steps I'd like you to try:
• Boot into Safe Mode (hold Shift while clicking Restart → Troubleshoot → Advanced Options → Startup Settings → Restart → press 4) and test sleep/wake cycles multiple times to see if artifacts occur with basic display drivers
• Enter BIOS setup during boot and navigate menus for 5-10 minutes looking for visual artifacts.
• Temporarily disconnect the Samsung and LG monitors, test with only the Koorui 24E4 using different DisplayPort cables if available
• Disable Sleep Mode Temporarily, Go to Settings → System → Power & Sleep and set both options to "Never" to test normal usage without sleep cycles
• Test Different GPU Drivers, note your current driver version and either roll back to a previous version or update to the latest available.
• When it happens again, note the exact time and circumstances, try the monitor power cycle, and check if artifacts appear immediately on wake or develop over time
The most important test is checking if artifacts appear in BIOS or pre-OS environments, as this will definitively tell us if we're dealing with hardware versus software issues. Please let me know what you find!
Randy T.
PS...when my wife says it happens all the time...I'm not about to question her...LOL.
Thanks for this. The artifacts haven't returned, so far. If it happens again, I'll follow the steps you provided and report back as necessary.
Thanks too for your time.
Hi @imaddicted2u,
Thank you for the update and I am sorry to hear that.
Before we proceed, let me check, have you tried the troubleshooting steps that you posted?
If not yet, please follow the steps that we provided and kindly observe the system.
Michael L.
