22662 Обсуждение
I'm using an Intel 4000 card in my laptop and just bought a UHD TV. I cannot get the card to drive the monitor at 3840x2160 @ 30mhz.
MMich18
Новичок
5 458Просмотр.
I'm using an Intel 4000 card in my laptop and just bought a UHD TV. I cannot get the card to drive the monitor at 3840x2160 @ 30mhz. I get the message "The custom resolution exceeds the maximum bandwidth capacity. That shouldn't be possible. Here's what I have:
Intel(R) HD Graphics 4000
Report Date: Friday, September 02, 2016
Report Time [hh:mm:ss]: 8:25:08 PM
Driver Version: 10.18.10.4425
Operating System: Windows* 10 Home (10.0.10586)
Default Language: English (United States)
Installed DirectX* Version: 12.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 8057 MB
Processor: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
Processor Speed: 2395 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 0.0
Current Resolution: 1920 x 1080
* Devices connected to the Graphics Accelerator *
Active Displays: 2
Inactive Displays: 1
* Monitor *
Display Type: Analog
Serial Number: GSM59d5
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: VGA
Device Type: Monitor
Maximum Image Size
Horizontal Size: 20.87 inches
Vertical Size: 11.81 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 870 (75p Hz)
1152 x 864 (75p Hz)
1280 x 800 (60p Hz)
1280 x 1024 (60p Hz)
1280 x 1024 (75p Hz)
1280 x 720 (60p Hz)
1400 x 1050 (60p Hz)
1440 x 900 (60p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 1E 6D D5 59 CE D1 06 00
06 17 01 03 68 35 1E 78 EA 33 31 A4 57 51 A0 26
10 50 54 A7 6B 80 B3 00 81 80 95 00 71 4F A9 C0
81 00 81 C0 90 40 02 3A 80 18 71 38 2D 40 58 2C
45 00 09 25 21 00 00 1E 00 00 00 FD 00 38 4B 1E
53 0F 00 0A 20 20 20 20 20 20 00 00 00 FC 00 32
34 45 4E 33 33 0A 20 20 20 20 20 20 00 00 00 FF
00 33 30 36 4E 44 53 4B 44 34 39 32 36 0A 00 B0
* Built-in Display *
Display Type: Digital
Serial Number: SEC4252
Gamma: 2.2
Connector Type: LVDS
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 13.39 inches
Vertical Size: 7.48 inches
Supported Modes
1366 x 768 (60p Hz)
* Digital Television * <------- UHD TV JVC LT-48UE76
Serial Number: SZM0030
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 44.09 inches
Vertical Size: 24.8 inches
Supported Modes
640 x 480 (60p Hz)
720 x 480 (60i Hz)
720 x 576 (50p Hz)
720 x 480 (60p Hz)
720 x 576 (50i Hz)
800 x 600 (60p Hz)
1024 x 768 (60p Hz)
1280 x 720 (50p Hz)
1280 x 720 (60p Hz)
1440 x 480 (60i Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (30p Hz)
3840 x 2160 (60p Hz)
3840 x 2160 (24p Hz)
3840 x 2160 (30p Hz) <------------ Get error trying this
3840 x 2160 (25p Hz)
4096 x 2160 (24p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 4F 4D 30 00 01 00 00 00
15 1A 01 03 80 70 3F 78 0A CF 74 A3 57 4C B0 23
09 48 4C 21 08 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 08 E8 00 30 F2 70 5A 80 B0 58
8A 00 C4 8E 21 00 00 1E 02 3A 80 18 71 38 2D 40
58 2C 45 00 C4 8E 21 00 00 1E 00 00 00 FC 00 4D
53 74 61 72 20 44 65 6D 6F 0A 20 20 00 00 00 FD
00 17 3D 0F 88 3C 00 0A 20 20 20 20 20 20 01 9F
02 03 4B F1 5B 05 03 01 12 13 14 16 07 1F 20 22
5D 5F 60 61 62 64 65 66 5E 63 02 06 11 15 10 04
29 09 07 07 15 07 50 57 07 00 83 01 00 00 6E 03
0C 00 10 00 00 44 20 00 80 01 02 03 04 67 D8 5D
C4 01 78 C8 00 E5 0F 00 60 00 00 8C 0A D0 8A 20
E0 2D 10 10 3E 96 00 C4 8E 21 00 00 18 8C 0A A0
14 51 F0 16 00 26 7C 43 00 C4 8E 21 00 00 98 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 68
* Other names and brands are the property of their respective owners.
Any ideas? I'm pretty disappointed in Intel right now. This shouldn't be happening.And I am using a HDMI high speed cable with Ethernet (AmazonBasics brand).
0 баллов
1 Решение
AlHill
Супер-пользователь
3 948Просмотр.
5 Ответы
AlHill
Супер-пользователь
3 949Просмотр.
This link may provide some help:
Doc
MMich18
Новичок
3 948Просмотр.
It works at 25mhz but not at 24mhz. Go figure.
Сотрудник
3 948Просмотр.
Hi Kalhoun,
I sent you the specifications of HD 4000. Let me know if I can help you with anything else.
3rd Gen HD Graphics Quick Reference Guide
https://software.intel.com/en-us/articles/3rd-gen-hd-graphics-quick-reference-guide
Mike C
MMich18
Новичок
3 948Просмотр.
No disrespect Intel, but the way your graphic reads, only the "DisplayPort" is limited to 2560x1600, there is a comma afterward and no resolution in front of the HDMI. I've run two different monitors at 3840x2160 off this Intel 4000 processor without issue until this last Windows 10 update.
Сотрудник
3 948Просмотр.
Hi Kalhoun,
The comma divides DP and HDMI resolutions. The graphics card might or might not support higher resolution with lower refresh rate.
Mike C
Ответить
