- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
segue doc em anexo como o solicitado.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I think you need to turn off Adaptive Brightness. See this article for more information: https://www.intel.com/content/www/us/en/support/articles/000033837/graphics.html.
Hope this helps,
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
My laptop doesn't have Adaptive Brightness. I believe is the graphic drive, because with the native windows driver this error doesn't happen.
But the native windows driver doesn't have all the functionalities.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Sorry, I got nothing further. Unless someone else has some ideas, I suggest that you play with the settings in the Intel Graphics Command Center app and see if any of the features is causing this.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hello NPasq,
I would like to confirm if you are still facing this behavior or if you were able to get this Adaptive Brightness feature working? If not, please provide the following:
- Did this feature work before? If yes, do you remember making any changes before this started?
- Have you tried consulting with Acer to see if this feature is supported on this system?
- Please provide the following:
A. DXDIAG report
- Go to Start > Run or Windows Key + R.
- On the Run prompt, type "dxdiag" then click OK.
- On the DirectX Diagnostic Tool window, click on Save All Information.
- Browse to a folder, type in a filename then click Save.
B. Intel® Graphics Command Center report:
- Press the Windows key.
- Write "Intel® Graphics Command Center".
- Go to the "Support" tab.
- Go to the "System Diagnostic" tab.
- Press "Generate report".
- Save the report in a .txt file and send it to us.
Sebastian M.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
hello Sebastian,
i can fix this problem whith this article about dynamic brightness:
https://www.intel.com.br/content/www/br/pt/support/articles/000039392/graphics.html
tks for your help.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
