- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I came to report a problem that happens in The Last of Us Part 2, red textures, the same thing that happened with Spider Man 2, but this time we may have a solution, since the video in the link below shows the game being rendered correctly on the Intel Iris Xe igpu with an old version of the driver
https://youtu.be/_rr4mB73QWE?si=o_hrOpVmTUEdaE2v
but as it is an old and not very stable version, there are many crashes and other performance problems, since with this driver FSR 3 and frame generation cannot be activated, so it would be good to have a more recent driver that renders the game correctly and perhaps brings better performance, I know that Iris xe does not meet the minimum requirements to run the game, but they could do the minimum to fix this, since 30 fps is playable for many people and perhaps doing this would fix Spider Man 2 in one fell swoop.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi viituuu,
Thank you for reaching out to the Intel Community Forum regarding the issue you've encountered with The Last of Us Part 2. We appreciate your detailed report and the effort you've put into identifying a potential solution. To assist us in investigating the issue, please provide the following details:
- What is the exact model of your laptop?
- Have you tried using the OEM driver for testing?
- Have you used DDU to completely remove all residual drivers and installed a new one?
- Have you tried adjusting the graphics settings?
- Did you verify the game files or reinstall the game?
- Could you provide a screenshot of your in-game display and graphics settings?
- Which gaming platform did you use to download the game?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
hello
1: Samsung Book 550XDA
2: Yes, i tested some drivers
3: No, I didn't think it was necessary
4: Yes, no configuration solved it
5: yes the game files are correct
6: Not now because I had to delete the game to free up space.
7: I used one of the game's official stores, Steam
Here is the file made with SSU
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi viituuu,
Thank you for providing the requested information. I will now further investigate this and will get back to you once a resolution is available. Thank you for your patience and understanding.
Archie D.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi viituuu,
I wanted to inform you that the IrisXE graphics card does not meet the minimum system requirements for this game. Typically, addressing such compatibility issues involves collaboration with the game developer, who generally does not provide support if the minimum requirements are not met.
Unfortunately, this means we are unable to resolve the issues related to the game when the necessary specifications are not fulfilled. We sincerely apologize for any inconvenience this may cause and appreciate your understanding in this matter.
If you need further assistance, please submit a new question as this thread will no longer be monitored.
Archie D.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I attached here a screen capture of the game running on high contrast mode, with the last driver available for iris xe. The game performs even a little better than part 1. Sooo please help us with this, it is clearly a driver problem.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
