23788 Discussions
dGPU Switch and Freeze Problem
RBalt1
there is a problem with laptops which have Intel CPU + GTX 1050/1050Ti/1060/1070/GT 640M. The problem is, whenever you try to do some action on the OS, discrete GPU is triggered and it causes a 0.5s freeze.
Some actions, which cause the dGPU to wake up and lock up the whole system for about 0,5 seconds are:
  • Left click on battery-icon in task-bar
  • Opening Chrome-browser
  • Opening Windows Image Viewer (app + classic Foto viewer)
  • Opening system control panel
  • Provocation any animation on task bar (e.g. thumbnail-preview, ...)
  • Loading a new tab in Firefox
Here is a video demonstrating Display Setting Freeze:
https://www.youtube.com/watch?v=b7K1SpCQgAY https://www.youtube.com/watch?v=b7K1SpCQgAY
Another video showing dGPU switch on a lot of simple tasks:
https://www.youtube.com/watch?v=-euiZmHZwlc https://www.youtube.com/watch?v=-euiZmHZwlc
Another one:
https://www.youtube.com/watch?v=txQZWfWFhlc https://www.youtube.com/watch?v=txQZWfWFhlc
We have tried updating every software possible, but no luck.
  • Intel driver
  • NVIDIA driver
  • Chipset driver
  • BIOS
  • Firmware
The problem can be found on all laptop brands: ASUS, Acer, Clevo, Dell, Gigabyte, HP, Lenovo, MSI, Razer.The problem can be solved by either disabling Intel GPU, which forces the system to always work with NVIDIA, or disabling NVIDIA GPU. Both of them is not an option though, as if you disable Intel, not only you will drain the battery faster, but also some games will stop working. If you disable NVIDIA, then what is the point of buying a laptop with a discrete GPU?There is a also a workaround: configuring https://github.com/jobeid/TrayPwrD3 TrayPwrD3 to always work with NVIDIA in the backgound. This keeps the NVIDIA GPU alive but also drains battery faster. And there is no poaint in that as it renders Optimus useless!So, manufacturers have to come up with a fix.Thank you.
Reported Models:
  • Acer VN7-793G
  • Acer Nitro 5 (AN515-51-536M)
  • Acer Nitro 5, i5 7300HQ, GTX1050 Ti
  • Acer Predator Helios 300 (PH317-51)
  • ASUS N580VD
  • Asus GL503VD
  • Asus GL503
  • Alienware 13 R3
  • Alienware 17 R4
  • Dell 7567
  • Dell XPS L521x
  • Dell Inspiron 15 Gaming 7577
  • Dell 7510 (Early 2017)
  • Gigabyte Aero15W
  • GIGABYTE P37XV6
  • Gigabyte P35 v6
  • Gigabyte Aero 15
  • HP Omen 15
  • HP Omen HD630 + GTX1050
  • HP Pavilion
  • Lenovo Y720
  • Lenovo Y520
  • Lenovo W530
  • Lenovo P51 Xeon
  • MSI GE63VR 7RF Raider 4K
  • MSI GS60 2PE
  • MSI GS43VR 7RE
  • MSI GS63VR 4K
  • MSI GS73VR 7RG Stealth Pro
  • MSI GS73VR 7RF
  • MSI GP62MVR 7RF
  • MSI GE72MVR 7RG
  • MSI GE73VR 7RE
  • MSI GE73VR 7RF
  • MSI GP72MVR
  • MSI GX63VR
  • Monster ABRA A7 V7.2 (Clevo)
  • Razer Blade 14
  • Razer Blade 14 2017
  • Razer Blade 2017
  • Samsung Odyssey i7 7700 + GTX 1050
  • XMG A517-dnj
  • XMG P507
Non-Effected Models:
  • MSI PL62 7RC
Effected Windows Versions:
  • W...
Bryce__Intel
Hello folks,
Thank you for your patience while we investigated this further. I understand the frustrations caused by this issue and apologize for the inconvenience it may be bringing you. By now, most of you have installed our latest graphics driver (https://downloadcenter.intel.com/download/27650 15.65.5.4982) and seen the right-click desktop issue resolved (and some other right-click stutters as well).
After implementing the code change, we noticed there were some remaining right-click stutters happening in various areas of the OS experience and that's what we've been investigating until now; we wanted to be very clear if we were still contributing to them. We've now concluded that we are not, we're only in the stack 1 millisecond which is acceptable and the remaining time is from other parties and the three others in the stack, to the best of my knowledge are aware, investigating, and treating this with high priority.
This concludes Intel's investigation so I'm now considering this thread closed, though Intel will remain in communication with the other parties to assist in any way we can should they desire.
Special thanks to coolrecep for reporting this and all the others helping with config details and testing so we could improve our drivers as quickly as possible. We value all of your contributions.
.:Bryce:.
smoha251
Ok,after alll these days of torture, the best solution is windows 1703 with UAC set to never notify.
MKuts
Occasionally I've found two users having the problem with Lenovo W530.
https://forums.geforce.com/default/topic/860554/geforce-mobile-gpus/windows-10-and-optimus/20/ https://forums.geforce.com/default/topic/860554/geforce-mobile-gpus/windows-10-and-optimus/20/ (user whitee-puzzle)
https://www.reddit.com/r/Windows10/comments/78c88d/a_windows_10_issue_is_causing_bad_stuttering_on/ https://www.reddit.com/r/Windows10/comments/78c88d/a_windows_10_issue_is_causing_bad_stuttering_on/ (user jd1ms4)
My point is, I have the same notebook Lenovo W530 at work, but it does not have those issues with the following setup:
Win 10 Version: 1709 Build 16299.248
Intel Driver Version: 10.18.10.4358
Nvidia Driver Version : 382.05
The Intel driver is somewhat older though. Not sure if it is worth to check that Nvidia driver version with and older Intel driver.
For my Gigabyte P37XV6 I can go back to Intel Driver 15.40.14.4352. I will give it a try in combination with the aforementioned Nvidia driver and report back.
MKuts
Unfortunately, for my Gigabyte P37XV6 the driver combination I mentioned did not change anything. Seems that the older Intel driver for Lenovo (10.18.10.4358 )came without functionality (or bugs) that newer versions have. 15.40.14.4352 seems to be already "infested" ...
I'm now thinking about getting a cheap Headless Ghost HDMI plug. Found it interesting since people said, that the problem does not come up once a display is connected, in this case a dummy.
RBalt1
What's the point when there is https://github.com/jobeid/TrayPwrD3 GitHub - jobeid/TrayPwrD3: Keeps dGPU on but idle until needed. This addresses the Windows 10 stutter/mouse freeze on du…
akeko
i prefer using 1703 without UAC
RBalt1
I have tried all the solutions told by many many people. I'll try 1703 and finally tell that it does not fix the issue. But I'm really bored. Like really!
akeko
1703 have only two regular lags. UAC and once lag on battery icon after reboot.
AShak4
Is there a specific version of 1703 we should use?
akeko
Microsoft Windows 10 Creators Update 1703 Download (Build 15063.0)
+ disable updates
i do stay on it since i did buy Alienware 17 R4 1070 GTX
AShak4
With latest nvidia and intel drivers?
akeko
yes latest drivers
it's doesn't matter on this windows with driver you using. its not affected to right click and many more lags
MKuts
<< "<span style="font-family: intel-clear, arial, helvetica, 'helvetica neue', verdana, sans-serif;">What's the point when there is https://github.com/jobeid/TrayPwrD3 GitHub - jobeid/TrayPwrD3: Keeps dGPU on but idle until needed. This addresses the Windows 10 stutter/mouse freeze on du…
I know that tool is free and it's really awesome that it was provided to the public. I'm just curious about alternative possibilities. Should that thingie work as expected I won't depend on maintenance of that TrayPwrD3 tool in case some Windows Update f*** it up, which seems to be worse than a 50:50 chance these days . E.g., should Direct X13 come up, it might cease working. So long
CDion1
I also noticed that on my Dell 7577, 1703 works best, except UAC screen. But i also noticed one thing- in device manager, with all installed drivers, there are one or two unidentified devices. Which i suppose are somehow detected after some updates. Because on 1709 i dont see that. Other than that, works flawlessly. But again, u have to disable at all - updates and push garbage from Microsoft
AShak4
if you identify which those deviced are could help troubleshoot the issue. Maybe those 2 are causing the lag. For exampel are intel and nvidia idemtified correctly?
CDion1
As far as i remember both nVidia and Intel were recognized. Now i'm on 1709 tho. But, i may revert to 1703 soon if this will continue as it is now. And i will make sure to find what is missing.
MBEDO
Hey !
I have the same problem with Lenovo Y520 / 16go DDR4 / 1060 6go / i5
speeeeeeed intel_admin
RBalt1
Installed 17115.1 and it does not fix the issue at all. But I gotta say, I felt just a little less freeze duration. Like 0.3s instead of 0.5s... I would like you to try it.
FFlam
Hello everyone,
I have the same probleme with my Lenovo ThinkPad T470p.
Drivers versions:
Intel HD 630: 22.20.16.4836
Nvidia GeForce 940MX: 23.21.13.9077
Windows 10 build 1709
STria
Had a good run without any problems on my Inspiron 7577 with GTX 1060 and i7 7700HQ but I can't exactly pinpoint what caused the system to behave normally. I have downloaded TrayPwrD3 but had it off during this time period when the laptop was absolutely fine. GeForce Experience notification icon also pointed the fact that the 1060 graphics card was not active during that time as well.
So how did this happen exactly? No lag on right click, while opening Control Center or anything else on that matter without having the activate the NVidia card or have TrayPwrD3 on at all. I am not sure if any of the Windows updates I had to download before restarting the computer and noticing that the lag is back have anything to do with the problem re-appearing or was it just the fact that I restarted the PC that made it re-appear ...
smoha251
Is this problem also in a g sync laptop??. Actually i got hands on a alienware 15 r3 . It had no issues like these so i opened up the task manager almost three to four system processes kept pinging the dgpu . So is there a way we can do that?
Acer predator helios 300
I7 7700hq
Gtx 1060
RBalt1
Kill the processes? Helios 300 is on the list. G-Sync does not solve it AFAIK.
