Intel® ARC™ Graphics
3359 Discussions
My rendering latency has been consistently high while playing CS,I’m using B580
KH114514
I used low graphics quality, and the task manager showed that my graphics card usage was not high,Perhaps there is a problem with the driver, please optimize it
Mike_Intel
Hello KH114514,
  1. When did you purchased the unit?
  2. Was it working fine before?
  3. Did you change any settings before the issue started?
  4. What is your Power mode settings?
  5. Can you share some screenshots of the issue?
  6. What are the troubleshooting steps that you tried so far?
Michael L.
Mike_Intel
Hello KH114514,
Michael L.
KH114514
1.At about 2025.2.6
2.No,My graphics card has been experiencing issues such as lagging and inability to play some games from the beginning. I thought it was a problem with my graphics card, but I found a B580 user online who had the same problem as me, so I guess it might be a driver issue
3.Nothing,I directly installed the graphics card and downloaded the latest driver from the Intel official website without making any adjustments to the software or hardware
4.Normal
5.I don't know what kind of screenshot to provide, so let me describe it in words: when I play CS, the normal rendering delay is about 8 to 20, but after a period of time, it will constantly change between about 13 and 120, sometimes even reaching 190. When starting some unpopular games, this situation will worsen, but for example, when I play Devil May Cry 5, everything is normal
I initially used 2K with default full medium image quality, but after one or two games (about an hour and a half), I started to experience lag. I noticed that the GPU usage was not high, so I tried to lower the graphics quality, which initially worked, but after a while, it started to lag again
6.I tried reducing the image quality, updating the driver, checking the circuit, and replacing the game for testing
Mike_Intel
Hello KH114514,
I am sending another follow up on the information that I requested.
Michael L.
