Intel® ARC™ Graphics
3320 Discussions
When pressing Alt-O it shows the wrong cpu activity for my 5800X3D CPU.
Erwin06
When i start up a game the CPU activity shows very low CPU usage 2% for my ryzen 7 5800X3D CPU.
Maybe the 5800X3D isnt yet supported by this driver software.
Best Regards
Erwin.
Gabriela_Intel
Hi @Erwin06
Thanks for your patience! I'm checking in to let you know that we did report your issue to engineering (bug id #14019202834). However we do want to set expectations it could take some time for the issue to be picked up.
We'll let you know once we have more updates regarding your issue.
Gabriela E.
Andres_Intel
Hello Erwin06,
Thank you for your answer, all the information you have provided has been really helpful.
I read the EA forum and that was very helpful, I will continue with the investigation to provide you with our point of view and with more steps if need it.
Andres P.
Andres_Intel
Hello Erwin06,
We have been working on the investigation and the issue seem to be only aesthetic, we plan to try to replicate it using different apps, please follow the steps below and attach the log file:
  • Open file explorer
  • Look for C:\Users\<your_username_here>\AppData|Local\Intel\IGN\logs
  • Send the files you find there
Andres P.
Erwin06
Hello Andres,
Here are the logs u ask for.
Regard,
Erwin
Only a maximun of 10 file is allowed i got 48 files.
Erwin06
10 more
Erwin06
10 more
Erwin06
10 more
Erwin06
And the last 8.
Andres_Intel
Hello Erwin06,
Thank you for your response, that was very helpful.
We will continue with the investigation, and now we will try to replicate the issue, as soon we have the results we will let you know.
Andres P.
Andres_Intel
Hello Erwin06,
We were working on the investigation, this is expected behavior and it occurs because Intel Arc Control uses instantaneous CPU utilization while other applications including Task Manager use a rolling average, thus resulting in different real-time readings for the same metric.
Let me know if you have further questions.
Andres P.
Andres_Intel
Hello Erwin06,
Andres P.
Erwin06
I dont need further assistant.
I just dont see the point of showing 2% cpu usage.
Erwin
Andres_Intel
Hello Erwin06,
Since this is an expected behavior, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
