Intel® FPGA Software Installation & Licensing
Installation and Licensing that’s includes Intel Quartus® Prime software, ModelSim* - Intel FPGA Edition software, Nios® II Embedded Design Suite on Windows or Linux operating systems.
1344 Discussions
Can I program Cyclone V devices without having a license? We have the programming file .sof. we don't want to compile.
MGhad3
AnandRaj_S_Intel
Hi @MGhad3​ ,
Yes, you can program .sof file without any license.
Open Quartus with 30- days trial mode or without compilation mode go to Tools-> programmer ->auto detect ->select device->right click and change the file ->click on start.
Intel altera recommended to use programmer from same Quartus version & edition used to generate .sof file.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
MGhad3
Hi @Anand​
Thanks for your response.
Does it allow programming SOF files containing NIOS processor? after programming do I have to keep the USB blaster plugged in? or it can be removed ? I noticed in Web edition you have to have the usb blaster plugged in.
AnandRaj_S_Intel
Hi @MGhad3​ ,
Yes, you can program SOF files containing NIOS processor.
1.If you have time-limited sof file,We have to keep the USB blaster plugged in.
2.Or If sof file is generated using licensed quartus tool it's not necessary.
Anand
MGhad3
thanks @Anand​
The last question is using the 30 day trial, is it possible to generate sof file? ( not a time limited)
AnandRaj_S_Intel
Yes, but it will be time-limited sof file for Quartus pro & Quartus std.
We can use Quartus Lite to generate sof(not a time limited) only if, we are not using any IP's which required license.
For example: If we use Quartus Lite to design a system with Nios II/f(which requires license) in 30-days train mode of quartus. Tool will generate a time limited sof file.
Anand
sstrell
You can also download just the Programmer if you don't want to download and install the full Quartus software:
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
Click "Select by Software" and then choose "Programming Software."
#iwork4intel
