Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
公告
1238 讨论
University IP doesn't appear in SOPC builder 9.0 sp1
名誉分销商 II
2,156 次查看
Hi, I installed the university IP but I can't see these cores in SOPC builder. I have QuartusII 9.0 sp1 installed. Do you have any idea why it doesn't appear?
Thanks..
0 项奖励
7 回复数
名誉分销商 II
1,098 次查看
You need to add the path in SOPC -> Tools -> Options -> IP Search Path
0 项奖励
名誉分销商 II
1,098 次查看
Thank you jrierab. Sometimes very easy things can be a big problem for beginners.
Now I can see the univ. ip cores so I tried to use the RS232 core. Unfortunately when I add the core in sopc, the configuration window opens and displays some errors. And I can't see any parameters to set such as Baud Rate. I attached a screenshot. Do you have any idea what I'm missing this time?
0 项奖励
名誉分销商 II
1,098 次查看
Did you install the latest 9.0 UP IP cores? There were errors on previous 8.0 cores when working with Quartus 9.0.
Check here: http://www.alteraforum.com/forum/showthread.php?p=23544#post23544
0 项奖励
名誉分销商 II
1,098 次查看
Yes, I installed 9.0 UP RS232 IP core from the link you give. I have also tried previous UP IP 8 core package with Quartus 8.1 and the same problem happened. If you have time can you try adding RS232 core in SOPC. Just to see if this is a general problem or not.
0 项奖励
名誉分销商 II
1,098 次查看
I did it already before posting the link. It works, at least it allows me to select baud rate and the rest of the parameters. Because of that I thought that maybe you were not using 9.0 cores.
The only question is that I'm working on linux with Quartus 9.0 without SP1 (which is not available in linux, or I did not found it). So, It is only a windows related problem, a SP1 problem or something special in your system.
One last warning, I suppose you "refreshed" your SOPC system when changing IP cores versions, did you?
0 项奖励
名誉分销商 II
1,098 次查看
I finally solved the problem. I figured out what the errors mean. The problem is in the original "Altera_UP_Avalon_RS232_hw.tcl" script file. There is a variable definition mismatch. For example in the .tcl file there is a line written;
add_parameter baud int 115200
What solved the problem is changing the "int" to "INTEGER" as;
add_parameter baud INTEGER 115200
I also replaced "string" with "STRING" in the file and got rid of all the errors.
I don't know writing tcl commands so I'm not sure why the original .tcl file works for "jrierab" and not for me unless I do these changes.
Is there another way to solve this problem without changing the original .tcl file?
Thank you jrierab for your continuing suggestions that lead me to find out the problem.
0 项奖励
名誉分销商 II
1,098 次查看
what salary i can expect after doing bca and mca from ip university?
0 项奖励
回复
