Intel® Optane™ Memory
Объявления
1387 Обсуждение
I am not able to enable Intel Optane Memory... Pls help.. My laptop is performing very slow... As i open the intel rapid storage technology it shows an error on the ssd 13gb and not able to enable intel optane memory..
BAlle17
Начинающий
6 934Просмотр.
In the Intel Optane Memory tab it shows"Your system appears to be Intel Optane Memory ready but no Intel Optane memory modules were detected in your computer... Someone pls respond as soon as possible thanks.....
0 баллов
1 Решение
AlHill
Супер-пользователь
6 783Просмотр.
I think you have other issues. And, your performance problem is caused by something else.
I recommend you take your device to a repair shop and have a technician look at it before you cause a serious issue. Also, you definitely should make a backup now.
Doc
Просмотреть решение в исходном сообщении
21 Ответы
AlHill
Супер-пользователь
5 920Просмотр.
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
BAlle17
Начинающий
5 921Просмотр.
Hi thanks for responding. Is this which you wanted? Check and tell me? I runned the System Support Utility
n_scott_pearson
Супер-пользователь
5 921Просмотр.
Have you enabled Optane support in the BIOS?
BAlle17
Начинающий
5 921Просмотр.
How to check that? Pl guide me.
n_scott_pearson
Супер-пользователь
5 920Просмотр.
Sorry, I can't help you. How this is exposed is different in practically every BIOS. You will need to contact your laptop manufacturer's support folks for this.
BAlle17
Начинающий
5 921Просмотр.
In the bios it is detected but the status is showing smart event...
BAlle17
Начинающий
5 921Просмотр.
Is there any way to reset it or something like that?
BAlle17
Начинающий
5 921Просмотр.
And yes i have enabled optane support... But it is saying that please install a compatable module in rapid storage technology
AlHill
Супер-пользователь
5 921Просмотр.
Did you, or do you, have an optane module? Did your laptop come with one?
Doc
LeonWaksman
Супер-пользователь
5 921Просмотр.
Hi @BAlle17​
  1. In the SSU report I can't see your Optane Memory Module.
  2. Please attach to your post image of Disk Management.
  3. In addition open ans Administrative Windows PowerShell (right click on Windows icon in right bottom corner).
  4. In the PowerShell, run command diskpart and press enter. Then run command list disk and press enter. Attach image of PowerShell to your post.
Leon
BAlle17
Начинающий
5 921Просмотр.
posted a file.
BAlle17
Начинающий
5 921Просмотр.
posted a file.
AlHill
Супер-пользователь
5 921Просмотр.
I see no optane module. You should procure an optane module.
Doc
BAlle17
Начинающий
5 921Просмотр.
So then why it is showing an error symbol on SSD and showing Your system is reporting one or more events and data may be at risk?
BAlle17
Начинающий
5 921Просмотр.
And why is it affecting my pc's performance.. My booting speed has slowed down my multi tasking speed is slowed down earlier it was very smooth..?
AlHill
Супер-пользователь
6 784Просмотр.
Doc
LeonWaksman
Супер-пользователь
5 921Просмотр.
Hi @BAlle17​
  1. I don't know why your system performance is low. It may be caused by other reason than Optane. I agree with Al that you have no Optane Memory Module installed in your laptop. Therefore your HDD can't be accelerated. I suspected this after analyzing your SSU report. I've asked for the images to confirm that.
  2. In case that you will have Optane memory installed and enabled you should see it in the "Storage" section of the SSU report. See the attached report from my computer, using Optane Memory.
  3. So, if you want to accelerate your HDD with Optane Memory, you need to buy one and install first. Before doing so, ensure with your laptop support that Optane is supported by BIOS.
Leon
AlHill
Супер-пользователь
5 921Просмотр.
Also, optane is not necessarily going to help you with a poorly maintained OS, startup programs, disk capacity, lack of memory, etc, not to mention your anti-virus and any viruses or PUPS. This is where the repair shop can help you.
Doc
LeonWaksman
Супер-пользователь
5 921Просмотр.
Download WD Data Life Diagnostics and check your drive.
Leon
n_scott_pearson
Супер-пользователь
5 736Просмотр.
Using a smartphone, take a picture of the BIOS screen that shows the S.M.A.R.T. event and upload and attach this picture to your response.
Ответить
