17255 Discussions
A comment causes compilation error !
AAlas3
Hey guys,
I am doing a project and I found out that this comment caused a compilation error! I just don't know why
comment : /*/\/\/\/\/\/\/\/\/\/\*/
could anyone please tell me why ?
sstrell
What does the error say? Perhaps the first * is being interpreted as the start and end of the comment.
#iwork4intel
AAlas3
it says:
"Object(the name of the signal) is not declared, Verify the object name is correct. If the name is correct, declare the object."
for all regs and wires inside the Verilog code
Vicky1
Could you please check with Verilog-2001 version? older version of verilog might not supported.
Vicky
AAlas3
Yes it is Verilog 2001, I think this happened because of the escaping mechanism in Verilog (\ " ")
