17268 Discussions
Can I change weak pull up status of a FPGA pin during runtime?
KAthu
I know that I can enable or disable weak pull ups in the project settings and create a bit stream.
But is there a way to change the weak pull up of a pin based on some logic during runtime? Is there a ip core which can support this?
Thank you.
sstrell
What are you trying to accomplish by doing this?
Some IP, like the external memory interface IP, automatically enable or disable termination (on-chip termination) whether performing reads or writes and do the same to the ODT for the external memory.
#iwork4intel
KAthu
I am connecting the FPGA to an external micro-controller. And depending on the program I am running on the micro-controller, I need to enable weak pull ups on the fpga pins. (Using external pull ups is not an option for me.). My fpga design is the same for every program I run on the micro-controller. Using several muxes I implemented on the fpga, I can change the FPGA configuration for different programs during runtime.
Right now because of the pullups, I need to build several versions of the design. But if I can enable/disable pull ups using some IP during runtime, I can keep a single bitstream.
sstrell
The only thing I can suggest is adding logic that looks at what program is running and pulls up the appropriate I/O based on that. Even partial reconfiguration, which is only supported on high-end devices, reconfigures the core of the design, not the I/O.
#iwork4intel
KAthu
Thank you for your reply.
Do you know how to pull up the appropriate I/O based on logic? This is what I am trying to figure out.
I could only figure out how to pull up a I/O using pin panner. But then I have to compile it to create a new bit stream. If can pull up the appropriate I/O based on some logic then I only have to compile it once.
ShafiqY_Intel
Hi KAthu,
Apparently, pull up the appropriate I/O based on logic is not possible.
You can only pull up it using Pin Planner or Pin assignment.
