17252 Discussions
Hi, Im trying to make testbench but i get this error (vsim-7) Failed to open readmem
antonto
** Warning: (vsim-7) Failed to open readmem file "D:/altera askhseis/tbtest999/stimulus.tv" in read mode.
# No such file or directory. (errno = ENOENT) : D:/altera askhseis/tbtest999/tbtest.sv(23)
This is the full message that i get....I have been searching for a solution but couldn't find any. Some help would be great!! Thanks in advance.
sstrell
Why is there a space in your file path?  Modelsim and pretty much all tools don't like spaces in paths.
SyafieqS
Angel,
Your path seem has space which would make the tool not able to navigate to it. Rename the path without space.
antonto
@SyafieqS  @sstrell  Thanks for replying! I changed the path and now im getting this error
** Error: (vsim-3033) topModule.svo(53678): Instantiation of 'fiftyfivenm_adcblock' failed. The design unit was not found.
# Time: 0 ps Iteration: 0 Instance: /topModule File: topModule.svo
# Searched libraries:
# D:/fpga19.1/modelsim_ase/altera/verilog/altera_mf
# D:/alteraAsk/topModule/simulation/modelsim/gate_work
Any ideas on what to do?
sstrell
SyafieqS
Angel,
Are you able to solve the simulation issue?
See if below discussion could be helpful.
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Problems-simulating-ADC-in-DE10-Lite-board-using-Quartus-Prime/td-p/698403
