17261 讨论
How do I avoid using a specific LAB or ALM in Quartus Prime?
Littlerice32
初学者
4,229 次查看
For example, I don't want to use a LAB named "LABCELL_X66_Y55_N6".
How do I let Quartus Prime know this, and avoid using this LAB in compiling my design?
Thank you.
0 项奖励
10 回复数
sstrell
名誉分销商 III
4,220 次查看
I'm not sure why you don't want to use a particular resource, but you can force logic into resources you do want to use with Logic Lock regions in the Chip Planner.  Draw shapes (rectangular by default; merge them together to make non-rectangular shapes) and assign logic from your design to a region.  Then the Fitter is forced to place the logic in that region.
Be aware that if you have a very full design, this could cause no-fit or timing issues due to you forcing logic into specific locations, away from where the Fitter would prefer to place it.
0 项奖励
Littlerice32
初学者
4,212 次查看
Hi sstrell:
   Thanks for your reply, but it's not the answer what I approach for.
   I want to forbid Quartus Prime to use a particular resource, because I find some particular LAB delay is 10x larger than a normal LAB in Timing Analyzer. After I use chip planner for post-netlist ECO to change the LAB resource to a adjacent LAB, the problem is solved. So, I think the 10x delay LAB may be something wrong.
   I appreciate it if you could kindly provide a solution for my request.
0 项奖励
sstrell
名誉分销商 III
4,198 次查看
I don't understand how a particular LAB could be slower than any other.  They are identical.  Can you share your .sdc and the timing report where you're seeing this?  There is some reason why the Fitter is selecting this LAB for you (super full design perhaps?) and causing the issue.  The extra delay may be getting a signal to a particular physical location, not the physical resource itself.  If that's the case, you need to figure out why the Fitter is doing this.
The ECO fixes it, but it might be useful going forward to understand the cause of the issue.
0 项奖励
Littlerice32
初学者
4,192 次查看
Hi Sstrell:
  I don't understand that either, but it happens.
  I provide the Chip Planner layout and Timing report here.
  The utilization of my design is 27%, and I think it's not an issue for FPGA fitter.
  BTW, if you know how to avoid using a specific LAB in Quartus Prime, please tell me how. Thank you.
0 项奖励
sstrell
名誉分销商 III
4,189 次查看
As I suspected, IC is interconnect delay where you're seeing the problem, not LAB (cell) delay.  For some reason, the Fitter is using long routing wires which doesn't make sense as you say since they're in the same LAB.
When you run Report Timing in the Timing Analyzer, turn on the Show Routing option.  That breaks down IC delay into RE (routing element) delay.
There must be some physical reason why the Fitter is doing this.  Again, it would also be useful to see your timing constraints, at least what speed you're trying to run this at.
0 项奖励
Littlerice32
初学者
4,181 次查看
Hi Sstrell:
  Thanks you.
  Your suspicion is right, and the large IC delay is caused by lots of RE delay.
  Though the data path is within the same LAB cell, Quartus II still deliver this long long routing path.
  Do you have any idea why Quartus II does it?
  My design is a simple image processor. The PLL clock in is 64MHz, and my design runs at 32MHz.
  Utilization = 27% on Cyclone V-E FPGA.
0 项奖励
SyafieqS
员工
4,164 次查看
Hi Sheng,
Any other concern on this?
0 项奖励
Littlerice32
初学者
4,159 次查看
Yes, the data path is within the same LAB cell, Quartus II still deliver a long routing path.  (10x larger than other path)
Is it a normal situation for a low-speed (32MHz) and low-utilization (27%) design?
Could you give me some opinions for explaining why Quartus II did this?
0 项奖励
sstrell
名誉分销商 III
4,152 次查看
Can you show the timing report details for the long path (including the routing and logic elements involved)?  The HDL for that part of the design?  RTL or Tech Map Viewer schematic?
Do you have any relevant assignments in the Assignment Editor that might be forcing this?
More info is needed to figure out what is going on here.
0 项奖励
SyafieqS
员工
4,126 次查看
Hi Sheng,
Any update?
0 项奖励
回复
