17252 Discussions
How to auto add commands into the Quartus project?
NuvKFC
I'm a GUI user. And I have the same design on the difference FPGA device.
So, I have three projects. The different setting of them only is the FPGA device name.
I don't want to set the same setting manually again and again.
How to do that?
I had tried to key the command as follows picture into a TCL file. And I really add the TCL file into the Quartus project.
However, it don't work.
Can anyone help me? Thank you very much.
By the way, I add TCL file into the Quartus project by using GUI.
Command in the TCL file:
sstrell
The files you add there are design files.
To do this, just manually edit the .qsf or add a "source" command in the .qsf to source your separate .tcl file.
sstrell
NuvKFC
Hi sstrell
     thank you, sstrell, very much. Can I use the Quartus GUI to add a  "source" command in the .qsf to source my separate .tcl files or .qip files?
     Or just only can manually add a "source" command in the .qsf file?
sstrell
No, you have to manually edit the .qsf.  There's no option for this in the GUI.
NuvKFC
Hi sstrell
     I get it. Thank you, sstrell, very, very much.
