17256 ディスカッション
Hyper-Retiming, How to disable it in the .qsf?
AEsqu
初心者
7,862件の閲覧回数
I'm asking because Quartus is not able to apply it on my design, hence I want to skip it to save run time (stratix 10, Quartus 21.1).
Messages from Quartus:
Info(16607): Fitter routing operations ending: elapsed time is 00:40:14
Info(17966): Starting Hyper-Retimer operations.
Info(18914): The Hyper-Retimer was unable to optimize the design due to retiming restrictions. Run Fast Forward Timing Closure Recommendations to see step-by-step suggestions for design changes and show the estimated performance improvement from making these changes.
Info(17968): Completed Hyper-Retimer operations.
Info(18821): Fitter Hyper-Retimer operations ending: elapsed time is 00:35:37
Alex.
0 件の賞賛
33 返答(返信)
Nurina
従業員
6,041件の閲覧回数
Hi Alex,
You can disable retiming using this command: https://www.intel.com/content/www/us/en/docs/programmable/683236/22-1/allow-register-retiming.html
Nurina
AEsqu
初心者
6,029件の閲覧回数
Thank You Nurina, I will test
set_global_assignment –name ALLOW_REGISTER_RETIMING OFF
AEsqu
初心者
6,021件の閲覧回数
The hyper-retimer is still executed after adding
set_global_assignment -name ALLOW_REGISTER_RETIMING OFF
in the .qsf
Note: In the fitter report/ignored assignments report it is not present, so it is taken into account.
Is there another command available to prevent that?
Nurina
従業員
5,993件の閲覧回数
Hi Alex,
I don't think you can entirely skip the Retime stage, the big selling point of a HyperFlex device is the ability to improve timing with the Retime stage. How much time is used for Retime stage?
You can try other steps to reduce Retime compilation time/effort.
Nurina
AEsqu
初心者
5,984件の閲覧回数
For one project it took 8 min,
for the other project it took 38 min (still unable to optimize the design, so it is maybe a big selling point, but if not applicable to our design ...).
I will try the other options you provided.
AEsqu
初心者
5,975件の閲覧回数
When I use aggressive compile time, Hyper-retimer runs as long as with balanced setting.
Enable intermediate fitter snapshot was already unticked.
Would it be possible to add an option in future release of Quartus to be able to turn it off?
I use Synplify for the synthesis, I can use retiming in that tool (yes I know that Quartus has a place and route overview that can lead to a better retime too over synplify).
sstrell
名誉コントリビューター III
5,957件の閲覧回数
Retiming normally does not take very long because it is using the post-fit netlist and doesn't make changes to that netlist.  All it does is make decisions about moving registers from LABs to hyper-register locations.
Retiming in a different tool would be based on the synthesis netlist.  That's a different type of retiming from the hyper-retiming performed on the post-fit netlist by Quartus.
Are you saying that just the hyper-retiming stage itself took 38 minutes or the overall compile was that long?
If just the hyper-retimer is taking that long, then maybe there is some other related setting enabled, or maybe a fast forward compile is being run automatically or something.
AEsqu
初心者
5,904件の閲覧回数
I think the hyper retime run time is directly proportional to the design size and/or timing requirements,
two examples below:
Nurina
従業員
5,936件の閲覧回数
Hi Alex,
I could certainly make a request for an option to disable it.
I need some confidential details from you, I will drop you an email.
Does above comment help to improve compile time by the way?
Nurina
Nurina
従業員
5,899件の閲覧回数
Yes, the retime stage compilation time would definitely take longer with a bigger project or if the tool is putting more effort in meeting timing.
Similarly all the other stages take longer time with a bigger project.
Nurina
SyafieqS
従業員
5,794件の閲覧回数
Hi Alex,
May I know if there is any update on this issue?
AEsqu
初心者
5,732件の閲覧回数
I think the next update should come from Intel side,
will there be an option added to disable entirely the hyper retime step in a future version of Quartus ?
That would save quite a significant amount of run time at my side,
as indicated before.
Kind Regards,
Alex.
Nurina
従業員
5,622件の閲覧回数
I can request for an option to disable it.
Apologies as it turns out I didn't send you that email previously mentioned.
Dropping you one right now so we can continue this case through email.
Nurina
AEsqu
初心者
5,451件の閲覧回数
The option I receive in the QSF
set_global_assignment -name ASIC_PROTOTYPING_FEATURES ON
is not helping, retiming is still running,
see attached picture.
Nurina
従業員
5,424件の閲覧回数
Hello Alex,
My apologies, this qsf setting is intended for Stratix 10 GX 10M, I can see that you are using Stratix 10 SX.
Let me check with internal team on the expectation of this qsf setting.
On the other hand, we strongly advise using Stratix 10 GX 10M for ASIC prototyping projects as this device is intended for ASIC prototyping and offers high capacity & large connectivity with the DIB IP and other features that makes it perfect for ASIC Prototyping.
More information regarding the Stratix 10 GX 10M here: https://www.intel.com/content/www/us/en/products/sku/210290/intel-stratix-10-gx-10m-fpga/specifications.html
DIB IP: https://www.intel.com/content/www/us/en/docs/programmable/683142/20-2-19-3-0/about-the-dib-fpga-ip-user-guide.html
Nurina
AEsqu
初心者
5,404件の閲覧回数
Ok let me know if you have another .qsf setting that would work for the Sx.
I will not change the FPGA, I could prototype all ASIC for the last 20 Years on the Altera/Intel FPGA:
(Cyclone 3, 5, Stratix 2, 3 ,10 and Arria 10).
Nurina
従業員
5,334件の閲覧回数
Please note that internal team is currently investigating your problem. I'll let you know of any updates.
Nurina
Nurina
従業員
5,304件の閲覧回数
May I know what is the frequency the design is running at?
Nurina
Nurina
従業員
5,290件の閲覧回数
Hi Alex,
Can you share me the design where the retime stage uses up long compilation time? I suspect that this is a bug.
You can share it through e-mail. I'm dropping you an email right now.
Nurina
AEsqu
初心者
5,170件の閲覧回数
Hi Nurina,
I'm not allowed to share my design.
Frequencies varies, lot's of clock domains.
Main's are around 45 MHz.
返信
