Preserving an Instance
SOkte
What is the synthesis attribute for preserving an instance (not register)
example: Blockram instance whose outputs are not used.
sstrell
There is none. If a block is not used, it might get optimized away.
If you want to do this, the easiest way to do it would be to add virtual pin assignments in the Assignment Editor on the outputs of the block.
#iwork4intel
Kenny_Tan
you can set it as a design partition, once it is set. Usually, it wouldn't simply optimized away the output of your block ram. But you had to make sure that your output of the ram is in the boundary of the design partition.
