17254 Discussions
Quartus II time limited .sof file
Contributeur émérite II
6 796 Visites
when I try to program my FPGA...it appears a advice window about a limited time .sof file generation...as shown in attached image. I'd like to know how I have to behave...
0 Compliments
8 Réponses
4 382 Visites
well.. If you want to use your code after the evaluation time has expired, you need to buy the IP core implemented in your programming - otherwise you won't be able to programm your FPGA.
If your evalution period has not expired yet, this is just a reminder ;-)
0 Compliments
4 382 Visites
Ok...but my .sof file to program my fpga is now <program_name>limited_time.sof....and I don't know what it happens if I use it for programming...do you know that???
0 Compliments
4 382 Visites
you can only use this file to upload it to the FPGA, and then you mustn't close the window as long as you want to use the FPGA. If you close it all the licensed components in the FPGA will stop working. The other limitation is that you can't put your design into flash. But other than that you have a fully functional system you can play with.
0 Compliments
4 382 Visites
thx..Daix...so if I disconnect the usb blaster cable or close that window...my system stops to work...but if afterwards I re-program FPGA with <program_name>_time_limited.sof again without disconnecting usb blaster cable and closing the OpenCore Plus Status window, Can I use my system for test???
0 Compliments
4 382 Visites
Yes, when you upload again the .sof file, your design will work again, as long as you don't close the window.
0 Compliments
4 382 Visites
Thanks a lot.... Daix...;)
0 Compliments
4 382 Visites
Hi, I have a Query.
I'm using the EMAC IP from ALTERA. I only have tool licenses, But I don't have EMAC IP license. Can I add EMAC IP interface signals ( TXD and RXD) to signal tap logic analyzer?
0 Compliments
4 382 Visites
Yes you can see the EMAC signals in signaltap, even if you don't have a license.
0 Compliments
Répondre
