17267 讨论
Quartus crashes during analysis and synthesis
HenryNS
初学者
917 次查看
I'm running quartus prime pro 17.1, trying to compile the simple socket server example (provided in the cyclone 10 gx kit collateral).
Every time I attempt to compile this project the progress bar reaches 16% and then quartus crashes on the info message "Analyzing source files" with no additional errors.
If I attempt to compile other example projects the compilation completes without error, just the simple socket server that crashes the software.
I've uninstalled and reinstalled quartus AND the example files but to no avail. Getting this example to work is critical for my work so would appreciate any assistance on this issue.
Kind regards,
Henry
0 项奖励
4 回复数
sstrell
名誉分销商 III
900 次查看
Have you tried trashing the qdb folder and recompiling?  Perhaps the compilation data is corrupted.
0 项奖励
ShengN_Intel
员工
889 次查看
Hi Henry,
Tested the simple socket server example in Kit Collateral (zip) from link below with Quartus Pro v17.1 and no problem with compilation. Memory RAM used 64GB.
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=253&No=1147&PartNo=3
Sheng
0 项奖励
ShengN_Intel
员工
872 次查看
Hi Henry,
May I know any update or should I consider that case to be closed?
Sheng
0 项奖励
ShengN_Intel
员工
856 次查看
Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
0 项奖励
回复
