- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
i installed Quartus v13.0 on ubuntu linux version 12.04 LTS. Everything works nice but whenever I start quartus I see the checkbox window where I can select the three license option (Buy Subscription, Run software, Add an IP license). I can then select to run the Quartus software and quartus starts and shows me a message box "Quartus II software is unable to activate your license". After pushing Ok it continues. When I go the license setup and click "Web License Update" to update the web edition license I get the message that I cannot connect to the internet and I see again the Box with the 3 license choices. When I configure the "Internet Connectivity" and set firefox as my web browser, I cannot start the web browser. Pushing, e.g. on "Documentation" results in the following message in the terminal where I started quartus: XPCOMGlueLoad error for file libxpcom.so: libxul.so: cannot open shared object file: No such file or directory Couldn't load XPCOM. There is a similar problem in the Xilinx software and there is i proposal to fix it: (not allowed here... google: xilinx XPCOMGlueLoad error) I followed the idea and renamed the libstdc++.so files to .bak versions. Then the firefox browser starts from quartus. However the license check is still not possible. Anybody out there who has the same problems? Regards FriedrichСсылка скопирована
3 Ответы
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Did you install Quartus as root?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
--- Quote Start --- Did you install Quartus as root? --- Quote End --- no. I installed as normal user. Regards Friedrich
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I think if you install as root (sudo ./setup.sh), this should go away. I noticed this when installing on another 12.04LTS machine today.
Now, to try and sort out fonts in Modelsim....
Ответить
Параметры темы
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
