Annonces
17268 Discussions
Schematic Editor Problem Quartus 21.4
GLees
Nouveau contributeur II
5 600 Visites
In the schematic editor the "pins" on the block symbols (generated by Quartus) don't line up with the grid points in the schematic editor.  This makes it look like the interconnections are "skewed".  The connections appear to be made correctly but it's very annoying.
0 Compliments
17 Réponses
sstrell
Contributeur émérite III
5 585 Visites
Where did you get this .bsf?  I've never seen this.  Dragging the symbol should make it align with the grid.
0 Compliments
GLees
5 577 Visites
The  .bsf was created by Quartus when I instantiated a PLL.  Dragging the symbol does NOT make it align with the grid.
0 Compliments
sstrell
5 569 Visites
Is it only this symbol?  Maybe there's an "always align to grid" option you have turned off accidentally.
0 Compliments
GLees
5 562 Visites
This is not the only symbol that acts this way.  I'm not aware of any "always align to grid" option but would be thrilled to hear about one if it exists.  I've looked through the Options menu and found nothing.
0 Compliments
ShengN_Intel
Employé
5 554 Visites
Open the .bsf file, click and adjust the black solid line to make it align with the grip points.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
0 Compliments
GLees
5 527 Visites
Thanks for the response.  I don't know what you mean by "click on the black solid line".  I've attached an archive of the project for you to inspect.  If you can make the grid points line up then we can talk further about how you did it.  If not, this is a bug in the bdf editor.
0 Compliments
ShengN_Intel
Employé
5 520 Visites
Done make changes to pll_deser_top.bsf file. Check pll_align.bdf (image) and folder attached. Can also use arrow keys to adjust will be more easier.
Sheng
0 Compliments
GLees
5 507 Visites
I have looked at your changes.  pll_align.bdf is still off grid.  Nothing changed.  Still a problem.
0 Compliments
ShengN_Intel
Employé
5 503 Visites
Sorry for misunderstanding your problem before. Now grips are aligned. Reattached the image and folder.
Sheng
0 Compliments
GLees
5 398 Visites
Thank you, and now can you tell me how you were able align the symbol to the grid?
0 Compliments
ShengN_Intel
Employé
5 391 Visites
In .bsf, allign the line with the cross will do (picture attached). Hopefully answering your question.
Sheng
0 Compliments
GLees
5 377 Visites
Unfortunately using the .bsf editor in Quartus 21.4 causes the program to crash and exit.  I get the following message whenever I try to edit the symbol in any way;
0 Compliments
ShengN_Intel
Employé
5 361 Visites
I'm not having any issue at modifying the .bsf file in v21.4 both linux and window check image below. Can you try to relaunch the Quartus or include the .bsf file into Project Navigator first then only open to modify. Or may be try with newer version?
Currently internal team is working on the .bsf not aligned bug or you can wait for newest version release?
Sheng
0 Compliments
GLees
5 341 Visites
I've tried relaunching Quartus many times with no success.  I'm unclear about "include the .bsf in Project Navigator".  Glad to hear the bug is being fixed.
0 Compliments
ShengN_Intel
Employé
5 332 Visites
Go to Project Navigator -> Files -> include .bsf file -> open to modify
Or try to reinstall Quartus, I'm not getting any issue on editing .bsf file in v21.4 window check image attached.
Let me know if you have any further concern or update.
0 Compliments
ShengN_Intel
Employé
5 224 Visites
Do you have any further concern or update?
Let me know if any.
Sheng
0 Compliments
GLees
5 221 Visites
Since I'm unable to modify the .bsf myself, I'll have to wait until this bug is fixed in Quartus.
0 Compliments
Répondre
