17247 Discussions
Timing Designer Inter-Path-Competition in Nios sub-system
CWarr1
Timing designer is reporting 'Inter-Path-Competition' issues for my Arria-10 FPGA design. The path that is highlighted is between the Nios processor and its associated onchip memory. Since both modules are created and connected within Platform Designer, I can not see how to duplicate the specified nodes.
Can anyone suggest how I might resolve this error?
Thanks!
sstrell
Can you show the error?  Timing info from the Timing Analyzer?  Need more details here.
I'm not sure what the "Timing Designer" is.  Do you mean the Design Assistant and you're failing a rule or something?
CWarr1
Apologies - I meant Timing Analyzer, not Timing Designer!
I will close this request and re-post with a corrected title
