17259 讨论
modelsim does not generate clock signal
名誉分销商 II
5,084 次查看
I am trying to use testbenches in a big project. Quartus created tb itself and I just added a few lines within this testmodule:
initial begin
clk_clk = 0;
end
always# 10 clk_clk = ~clk_clk
Then by using RTL simulation I opened modelsim which added all wires of the project correctly but it is not simple generate clock
pic related
1) I did not find any explanation about grey lines. Why it even Pu0 (pull down?)
2) What did i wrong? I tried to follow altera RTL simulation guide
Looking forward any help :c i am very new to Quartus
0 项奖励
11 回复数
名誉分销商 II
4,292 次查看
It seems like Modelsim dont see my "always" blocks in testbench at all. Anything i write is not show up during RTL simulation
0 项奖励
名誉分销商 II
4,292 次查看
Did you set the testbench as the top level?
0 项奖励
名誉分销商 II
4,292 次查看
--- Quote Start ---
initial begin
clk_clk = 0;
end
--- Quote End ---
Let me know,
1. Are you able to compile Design & Testbench successfully?
2. All Inputs/Outputs are declared & initialized properly or not(declaration of clk_clk should be reg)?
3. can you provide code?
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
0 项奖励
名誉分销商 II
4,292 次查看
Meaning did you instantiate your design under test in this testbench?
0 项奖励
名誉分销商 II
4,292 次查看
Thank you for all replies!
Well. Firtsly I created Testbench skeleton by Processing -> Start -> Test bench Writer
Then i added its link in Assingments -> Settings -> Simulation -> Native link settings
I modified TB with a few lines for modelsim to generate clock signal (just to try how it works)
But it is not work, even if i try to assing anything to 1'b1 or whatever.
Please guide how it supposed to work :c
clk_clk generated as reg
0 项奖励
名誉分销商 II
4,292 次查看
Replace sysclk by sysclk_period
It`s simple just provide input stimulus for example as follows & simulate,
always @(posedge SYSCLK_PERIOD) begin # 5 reset_reset_n = 1; # 50 reset_reset_n = 0; # 100 reset_reset_n = 1; # 25 reset_reset_n = 0; # 55 reset_reset_n = 1; end
find the attachment for screenshot.
Best Regards
Vikas Jathar
0 项奖励
名誉分销商 II
4,292 次查看
I replaced but still getting those strange pictures. I am sorry, but clock_period is a parameter (constant) how you made it posedge? Could you please provide me with your testbench file?
Thank you for your attention!
0 项奖励
名誉分销商 II
4,292 次查看
Yes, It should be "clk_clk".
Refer attached testbench file & run for more time like "run 50 ms".
Best Regards
Vikas Jathar
0 项奖励
名誉分销商 II
4,292 次查看
Nothing helps me :c
Maybe smth broken in Native link connetion. But when I intentionally made mistake in .vt file, Modelsim reported me about it so it sees and updates it during RTL simulation.
You seemed to simulate this project without Quartus, how?
0 项奖励
名誉分销商 II
4,292 次查看
I created own simple design file relative to the .vt file, refer the attached files & try yourself with fresh new project in Quartus tool.
Best Regards
Vikas Jathar
0 项奖励
名誉分销商 II
4,292 次查看
RTL simulation finally works! I used your guide and this helps!
Now i see it all the matter of names. I've used the name of TB file in native link settings, not the name, which Quartus gave to TB module.
Thank you a lot!
0 项奖励
回复
