I am new to signaltap and also had some questions.
I have this code ... always @(posedge signal_delayed_2 or negedge reset_n) begin if (!reset_n) start_signal1 <= 8'h00; else # 1 start_signal1 <= counter; end always @(negedge signal_delayed_2 or negedge reset_n) begin if (!reset_n) stop_signal1 <= 8'h00; else # 1 stop_signal1 <= counter; end My counter rolls over after 2**10 In RTL and gatelevel simulation it works fine and in signaltap and on o-scope it shows different values for start_signal1 (+- 2) from actual values, even though I am feeding a constant pulse to signal which is delayed by 2 clocks for synchronization). Please let me know if you have ideas/suggestions.Link Copied
Your problem is not clear. But I observe:
your clk named signal_delayed_2 sounds gated...beware of gated clk problems. your# 1 is ignored in synthesis if your start_signal1 is delayed by 2 clks then it will follow counter by two clks leading to +-2 difference depending on how you are kicking the counter...- Mark as New
I am getting signal_nodelay (asyncronous to my clock) and then I pass it through 2 flip-flops for synchronizing it to my clock.
The counter is running synchronized to the clock. so if the posedge of signal_delayed_2 occurs when counter = xAA2 signaltap would sometimes report that start_signal1= xAA0 or xAA4 or xAA2 at various samples. also wouldn't I delay the assignment of counter to start_signal1 by 1 timeunit after the posedge of signal_delayed_2- Mark as New
There isn't enough information I am afraid.
All you have is start_signal1 chasing counter(one register in between). Ofcourse start_signal1 should follow counter by one clk edge. But is your signaltap sampling clk correct and is there anything else driving start_signal1. You better post all your code to see what you have done!
Topic Options
