17252 Discussions
using UART to communicate between fpga and pc
MFort6
Hi
i am using Altera Stratix® V GX FPGA (5SGXEA7N2F45C2) and i have designed the UART program to communicate between the fpga and my pc. and the compilation was a success, but the problem is when i try to assign the UART tx, rx  pins. i can't find any in the data sheet. so i need to know is there any other way or do i need to change the bord?
Thank you
ak6dn
Valued Contributor III
See my reply in the Programmable Devices forum, as you posted the same question in both.
