SL6JE KC333/256
transiente
Good afternoon to all forum members.
I have a problem with the soldering temperature performance of the SL6JE 333MHz/256MHz processor.
I know this processor is quite old, but it's still used today in aircraft displays.
Does anyone have any information about this chip?
I'm using an automatic precision rework station.
When it reaches 220°C, the soldering is perfect, but it kills the chip.
Thank you.
AlHill
It is an old Pentium:
https://www.electronicsdatasheets.com/manufacturers/intel/parts/kc80524kx333hw-sl6je
[AI is the same as snake-oil]
transiente
Good morning Al Hilal
Unfortunately, the link doesn't work.
Thank you.
transiente
AlHill
Just test it and it works for me.
n_scott_pearson
@AlHill,
While it's true that the link to the Electronic Data Sheets site works just fine, the link on that site to actually download the datasheet doesn't work.
@transiente,
I found a part listing at Rochester Electronics that does have a link to a datasheet (see here: https://www.rocelec.com/part/01t4w00000PPGPuAAP-KC80524KX333HW). If the linked datasheet is the correct one, great, you have what you need. If not, however, let me know exactly what the part is; I have a fairly extensive collection of datasheets and may have what you need.
transiente
Good afternoon, AlHill.
Thanks for your help.
I downloaded the datasheet, but it doesn't mention the soldering temperature.
I tried it at the standard temperature, and it solders well, but it kills the chip.
It shorts out. I think there must be a different way to solder it.
I've already lost three parts trying.
If you can help me with this, I'd appreciate it.
Thanks again.
AlHill
Sorry, but I do not think you will get much help/support on a 30-year-old product.
transiente
Good morning everyone.
I appreciate the help I received.
If you have a solution, please post it here.
Thank you.
