16766 Diskussionen
Which is the latest microcode for intel i5-13500 S series processor.
VARADHARAJAN
Geschätzter Beitragender II
8.050Aufrufe
Currently I am using an assembled desktop.
Processor  :: Intel  i5-13500 S  processor
Processor ID ::  0xB06F2
Motherboard :: Gigabyte B760M DS3H AX
RAM capacity and model :: 64GB (16 GB x 4 )  G.Skill Ripjaws S5 Intel XMP DDR5 16 GB (5600 MHz CL36-36-36-89) (F5-5600J3636C16GX1-RS5K)
Dedicated graphics card :: Gigabyte  GeForce RTX 3060  windforce  oc 12G 2.0 (GV-N3060WF2OC-12GD)
Power supply :: MSI MAG A650BN 650W, 80 Plus Bronze Certified
Case fans :: 11  fans
Currently, I installed the latest, F21a with microcode 0x38, and I flashed the Intel ME firmware 16.1.35.2557 to this i5-13500 processor.
Also intel recently identified   A potential security vulnerability in the Intel® Slim Bootloader
INTEL-SA-01290
I am requesting an Intel moderator reply to my question as a priority.
Thanking you
Varadharajan M.sc B.ed
1 Lösung
Mike_Intel
7.693Aufrufe
Hello VARADHARAJAN,
Thank you for the clarification.
I believe the details of Microcode 0x3a was already shared in this thread.
Additionally, you may contact the manufacturer of the motherboard also for further assistance.
Michael L.
Lösung in ursprünglichem Beitrag anzeigen
9 Antworten
RobbieR_Intel
7.984Aufrufe
Hello VARADHARAJAN,
Thank you for reaching out to our Communities. I understand that you would want to know the latest Microcode Patch available for your 13th Generation Processor.
To clarify, are you referring to your processor as an i5-13500 or as a i5-13500KS?
The latest available Microcode Update for your Motherboard, Gigabyte B760M DS3H AX would be the 0x12F Patch.
However, on some motherboard, like for example an ASUS Z790 Motherboard would have the latest microcode patch, 0x12F.
The latest BIOS of your Motherboard, F20, only has the 0x12B Patch available there.
If you would want to install the latest Microcode Patch, 0x12F, I highly suggest you contact Gigabyte for further instructions or information regarding this.
If you have further questions from us on our end or further clarifications, please do let us know.
Robbie R.
Dan0987
Neuer Beitragender I
7.940Aufrufe
I may be mistaken, but I'm quite certain that 0x12B and 0x12F is for RPL-E/HX/S. The most recent microcode for i5-13500 (Alder Lake, deceively marketed as Raptor Lake) is currently 0x3a.
VARADHARAJAN
7.868Aufrufe
@RobbieR_Intel
Thanks for  you replying to me.
My processor is an i5-13500 processor BIOS F21a with current microcode 0x38. I installed this BIOS on 15th May 2025 before publishing it to the Gigabyte site.
13500 is  non K/KF/KS  processor.
Thanking you.
Varadharajan K
Dan0987
7.864Aufrufe
Mike_Intel
7.787Aufrufe
Hello VARADHARAJAN,
Thank you for the update.
Let me share the link below. Intel is about to release a new microcode. For its availability, you need to coordinate the manufacturer of the board on when can they release the new BIOS update.
Intel Core 13th and 14th Gen Vmin Shift Instabilty Update - New Microcode Update (0x12F) - Intel Community
Michael L.
VARADHARAJAN
7.752Aufrufe
@Mike_Intel
Thanks for replying. Unfortunately, processor i5-13500 does not affected by the Vmin Shift Instability Root Cause
I am asking about this issue. Intel® Slim Bootloader identified on 13th May 2025.
INTEL-SA-01290
I need the above issue. microcode.
Thanking you.
Varadharajan K
Mike_Intel
7.694Aufrufe
Hello VARADHARAJAN,
Michael L.
VARADHARAJAN
7.622Aufrufe
@Mike_Intel
@Dan0987
Thanks  for  the update. I will contact the Gigabyte manufacturer for a new update.
Thanking you
Varadharajan K
RandyT_Intel
7.408Aufrufe
Hello VARADHARAJAN,
Thank you for your update. As the best support for your inquiry is provided by the motherboard manufacturer, we recommend contacting Gigabyte directly for further assistance.
Should you encounter any issues in the future, please feel free to submit a new ticket. We are here to assist you with any further concerns. I will proceed with closing this case. Please note that it will no longer be monitored.
Randy T.
Antworten
