Programmable Devices
21602 Discussions
Cyclone 'EP1C3T100C8N' schematics
I have searched high and low and just cant find a simple schematic (bare minimum) to get this chip up and runnning.
Im just after how you wire it up with a JTAG interface and a simple boot prom.
Any idea where i can find this?
Thank you
--- Quote Start ---
--- Quote End ---
Have you read the device handbook?
http://www.altera.com/literature/lit-cyc.jsp
Generally, you need to power up the core voltage and each of the I/O banks within a specified time, configure the JTAG interface with appropriate pull-ups or downs on the signals (so they do not float when the USB-Blaster is not present), and wire up the EEPROM.
For example designs, just look at the schematics for a reference board. Don't worry if you cannot find an EP1C board, look for a Cyclone II or III, the JTAG and EEPROM interfaces have not changed.
Cheers,
Dave
I see, iv attactched the schematic of the development board im using. but i would like to use a EP1C3T100C8N in my actual design not the EP2C5T144C8
So the JTAG and boot prom connections will be identical on the EP1C3T100C8N, its just a matter of using this chip and wiring it up the same as the EP2C5T144C8
Im a bit scared of forgetting to GND some special pin or having to have one held high
--- Quote Start ---
--- Quote End ---
The schematic looks fine.
If I don't have a processor implementing the programming interface, then I like to put LEDs on signals, eg. the STATUS# signal will go low when there is a problem, so you can put a red LED on that and the CONF_DONE signal goes high when the FPGA is configured, so you can either use a red LED to indicate not configured, or a green LED to indicate its configured (I generally use a TinyLogic to drive LEDs; sink or source depending on when you want the LED on).
Here's a reference schematic and some other docs:
http://www.ovro.caltech.edu/~dwh/carma_board/
http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_rev_a.pdf
Cheers,
Dave
Just checked the schematic part, I cant beleave how simple these things are to setup :)
--- Quote Start ---
--- Quote End ---
Still, people do get it wrong ... as recent threads show. Here's few warnings;
1) Connection all VCCIO power banks, even if you do not use pins on those banks.
2) If the package has a power-pad (underneath it), make sure to connect it.
3) Connect all the device-specific programming pins appropriately, eg., nCE, MSEL[], nCONFIG, nSTATUS, CONF_DONE, (optional INIT_DONE), etc.
4) Connect the JTAG interface. Use a shrouded header for the PCB layout, as it helps to get the cable orientation correct. Make sure you leave enough room around the part.
5) Include a power-on-reset supervisor IC external to the FPGA. Its nice for producing a nice clean reset signal. You can usually connect a push-button input into the reset supervisor IC, and it'll debounce the signal for you.
Look at other peoples designs, try to understand them.
Cheers,
Dave
Ill make sure to upload my schematic once complete :)
